Previous in Forum: Tips for Improving Brake Linings?   Next in Forum: For <1MW capacity which is better for electricity generation
R134a flowrate
05/07/2007 2:20 AM
Anyone has the formula for liquid refrigerant R134a flowrate and pressure drop calculation? Need to calculate the above for R134a liquid centralized supply system.
Thanks
Pathfinder Tags: R134a
Re: R134a flowrate
05/07/2007 11:42 PM
Try the following:
The: HARI (The Heating and Air conditiong Institute), http://www.hrai.ca/ or RSES (Refrigeration Service Engineers Society), http://rses.org/main/index.cfm
Re: R134a flowrate
05/08/2007 11:10 AM
Not sure what your asking in reference to pressure drop calculations, but from my past work in developing refrigerant pressure transducers, I can tell you that there are charts that list the pressure range of any type of refrigerant with their corresponding temperatures. At any specific temp, there is a specific pressure, not a range of pressures. For flowrate, don't know professionally, only an opinion, but I would think the only special requirement would be understanding the specifications on rate of temperature change and response time. (Since you've chosen R134A, I would assume you have already chosen the temp range). Unstanding these 2 variable, along with knowing the viscosity of R134A, will help you determine volumes & flow rate. Again that is my personal opinion based on my knowledge in developing refrigerant sensors & testing systems.
Re: R134a flowrate
05/09/2007 9:52 PM
Thank you guys for the reply.
Unfortunately the website doesnt help and yes i do have the temperature pressure chart with me. But I need formula for calculation or something which ready for fill in with the parameter.
Cheers!!
Register to Reply 3 comments
Anonymous Poster (1); Heinrick (1); Sonave Sunsets (1)
