I was drying sun-dried small trash fish (semi-decomposed 3-4 inch long)in a co-current hot air direct-fired rotary drier 25 feet long, 5 feet diameter driven at 8rpm through a reduction drive but found that though the sun dried fish (about 40 % moisture content) would get dried but its shells/scales would not get rendered, ie cooked or crumbled. To overcome this problem I even injected some steam into the material but to no avail. What should be done with the dryer so that the fish scales too get ''cooked'' or at least crumble at the time of pulverizing??
I know you need a ''cooker'' to digest fish scales but when I do that the whole fish gets messed up into a soft sticky semi-solid mass which is impossible to dry down to 14 percent moisture content with the said dryer as it sticks to the dryer's inner wall. Even Installing hammers to the walls would not help.
Moreover, I tried to dry fresh trash fish too but it as well sticks to the interior walls of the rotary drier. Any way I can overcome sticking problem with my dryer??
Does anyone know how to cook and dry shrimp shells/heads etc by a continuous rotary cooker-dryer suitable for small scale production??
