Previous in Forum: Problem with PW Loop Water   Next in Forum: Boiler Feed Pump
Beam Deflection Apparatus
03/22/2012 4:43 AM
Can someone help me with information on the design of beam deflection apparatus and the product of beam deflection apparatus? Thanks!
Pathfinder Tags: BEAM DELFECTION APPARATUS
Re: BEAM DEFLECTION APPARATUS
03/22/2012 8:54 AM
Have you tried searching?
Where have you looked.
Please include a complete list of all the sites you have searched.
03/28/2012 8:11 AM
I've checked www.deltalab.fr/uk/produit.php.
The apparatus is to be used for bench mounting. Its components are the beam material, size, support spacing and loading.
Good Answers: 19
Re: Beam Deflection Apparatus
03/23/2012 9:21 AM
What type of beams?
What size beams?
Check EAA magazine archives, I think they had an article for a wood beam testing apparatus for testing wood strength.
03/28/2012 8:18 AM
The apparatus is to be used for bench mounting and/or enable students carry out experiments on simply supported and cantilever beams. Its components are the beam material, size, support spacing and loading.
Dimensions and weights
Nett (excluding set of weights)1400x240x380mm, 28kg
Good Answers: 19
03/29/2012 12:09 AM
Send me a private CR4 message with your email address, and I will send you PDFs of articles that might give some ideas of what you might build.
lyn (1); osicogi (2); Ried (2)
