Previous in Forum: Thread Type   Next in Forum: Comparison Between DX-System and Child Water System
10 comments
WPS for Welding 32 20 to T11
03/22/2012 1:53 PM
Anybody know How to make WPS for welding G-X10NiCrNb 32 20 to T11 material, the size of piece to be welded 6" thickness 12.5mm.
Re: WPS for Welding 32 20 to T11
03/22/2012 2:57 PM
Have you completed your WPQR?
03/22/2012 3:29 PM
I googled "WPS for welding" and got :About 159,000 results (0.57 seconds)
    Now, is it really so incredibly difficult that you can't do that?
03/22/2012 3:38 PM
It will be if he can't first establish a PQR.
03/22/2012 4:27 PM
If he uses a WPS, is a PQR required? Not to say he doesnt have one!
03/22/2012 4:29 PM
03/22/2012 4:54 PM
Yes, a PQR is required for a proper WPS.
A PQR is the record of the design stage weld that is tested, and how the weld was performed. After it is determined the produced test weld is sufficient, the WPS provides a weld operator with the information necessary to reproduce the results of the tested welded joint.
[edit] For a better worded explanation, I went to Wiki: The AWS defines welding PQR as a record of welding variables used to produce an acceptable test weldment and the results of tests conducted on the weldment to qualify a Welding Procedure Specification.
03/23/2012 5:38 AM
Welding Procedure Specifications (WPS)
This document details the practical application of the Procedure Qualification Record (PQR). It should contain enough information to give direction to the welder and should address all variables associated with the welding process defined in QW250 including non essential and supplementary.
A WPS can combine welding processes from many PQR's but all the relevant variables must be addressed including parent metal thickness. There is an exception to this rule for root runs from PQR's that are greater than 1.5 inches thick (38.1mm), see code for details.
03/22/2012 4:29 PM
one would do?......can you select one for me?
03/22/2012 5:07 PM
Sure. I'd use referrence # 146,435.
It is the most complete.
03/23/2012 8:13 AM
Thank you dear sir for your help and assistance
Register to Reply 10 comments
Doorman (3); lyn (2); Mukesh0861 (1); phoenix911 (4)
