Previous in Forum: Leonardo was Right!   Next in Forum: laser beams
14 comments
Continuous Type Jaw Crusher
03/23/2012 3:38 AM
I have a plan to design continuous jaw crusher which is having 1 fixed jaw and 2 movable jaw. Also should have two double eccentric shaft for driven mechanism. Suggestions and advices plz.
DESIGN ENGINEER
Pathfinder Tags: Continuous Jaw crusher
Good Answers: 183
Re: continuous type jaw crusher
03/23/2012 5:34 AM
there is an interesting paper on the net EXACTLY on this subject try under "continuoous jaw crusher".
Good Answers: 18
Re: Continuous Type Jaw Crusher
03/23/2012 9:52 AM
Hi rajesh,
It sounds like you have an idea not a plan.
You should do the design yourself, if your degree is going to be worth anything.
As suggested elsewhere, put your "title" in google and you will find existing manufacturers.
Regards,
John
Best advice I can give as you get older "Never miss an opportunity to relieve yourself"
03/23/2012 9:52 AM
Well, go ahead and design it. We are not going to do it for you.
See this:Design of Toggle Plate In Jaw Crusher
DO YOUR OWN HOMEWORK!
03/23/2012 4:51 PM
Suggest you try making such a crusher on the principle a ' half-'moon' or crescent type liquid pump is constructed,ofcourse you will have to make some modifications in design. You can also modify Root's blower for a try. Design it for top feed with bottom discharge
A modified version of this pump might solve your problem...
Instead of one central rotary jaw crusher you can install two eccentric ones on a double eccentric so that with every revolution the one moves away while the other crushes.
03/23/2012 5:36 PM
thx alot......
DESIGN ENGINEER
Safety - Hazmat - New Member Engineering Fields - Mining Engineering - New Member Engineering Fields - Construction Engineering - New Member Hobbies - Hunting - New Member
Good Answers: 12
03/29/2012 12:53 PM
This design is more in line with acone or hammer mill then jaw crusher.
John J Baker
03/23/2012 5:04 PM
here arre so many other choices for you,,,,
03/23/2012 5:43 PM
thx.i preferred the 2nd one.Bt with the help of two eccentric shaft how can i carry out the up and down motion of the fixed jaw?
DESIGN ENGINEER
03/23/2012 5:51 PM
Why do you want to move the 'fixed jaw' up and down???
You may snatch yet another idea from Jordon mill.....
03/24/2012 2:06 AM
oh srrry.that was my mistake. I mean movable jaw is located between two fixed jaws.so how can i perform up & down motion of the movable jaw which is been located in the centre?
DESIGN ENGINEER
03/25/2012 9:22 AM
you can use a crank or a double crank or even a cam fitted with a connecting rod!
Good Answers: 12
03/29/2012 1:03 PM
The design your looking at is called a cone crusher.
A jaw crusher is much different. you have a hard steel plate that another hard steel hits this is run by a piston hook up to a drive shaft.
John J Baker
Good Answers: 12
03/29/2012 12:58 PM
Again most of these are not jaw crushers.
Just go on google and type in jaw crusher designs there are tons of pictures out there. Our better yet contact a manufacture of crushing plants they should be able to help also.
John J Baker
Engineering Fields - Electrical Engineering - New Member Engineering Fields - Power Engineering - New Member
03/24/2012 9:07 PM
fwiw, study the continuous crushers used in rock crushing plants where they make gravel.
BSEE but always learning
Register to Reply 14 comments
1capybara (1); bakerjohn (3); jesw55 (1); lyn (1); mazhur (4); nick name (1); rageshchandran (3)
