Previous in Forum: Tank Calibration   Next in Forum: How is This Part Called in English?
Bearing Differentiation
03/26/2012 6:21 AM
I have a bearing fan 22220 CC/C3.
I want to replace this bearing with 22220 E/C3 .
Can it advisable to replace.
Please give your comments.
Regards,
Santosh
Re: Bearing differentiation
03/26/2012 6:40 AM
As the CC/C3 is not listed now, how about making a telephone call to SKF to check?
Re: Bearing Differentiation
03/27/2012 12:57 PM
CC stands for Spherical Roller Bearing and material is Ceramic While E stands for Double row conveyer bearing ,seal and shield ,sloted for bracket mountaining ,regid design.
If you born poor its not your mistake but if you die poor its your mistake
03/27/2012 1:05 PM
CC stands for Spherical Roller Bearing and material is Ceramic While E stands for Double row conveyer bearing ,seal and shield ,sloted for bracket mountaining ,regid design.i think u can replace it without any problem.is that bearing used in Snu-520 housing?
04/01/2012 12:10 PM
But why you want to replace? Technically very minor diffrence is there between the two models. In CC/C3, centring ring rest on inner race and in E/C3, with dia more then 65mm (as your case is), centring ring is fixed in the cage. This helps in better distribution of the lubricating oil.
Below 65mm size two types are same.
If you are getting as an alternate, you can go ahead.
Register to Reply 4 comments
Mukesh0861 (1); PWSlack (1); rajesh1986 (2)
