Previous in Forum: Problem with ATS48C17Q   Next in Forum: Poor Power Factor When Using Generator
Calculation Of Nominal Voltage Tap Ratio
03/26/2012 12:24 PM
How do you calculate the nominal voltage tap ratio for a power transformer, given the winding ratios and voltage ratings of the transformer?
Pathfinder Tags: nominal ratio tap transformer
Re: Calculation Of Nominal Voltage Tap Ratio
03/26/2012 12:34 PM
Good Answers: 181
03/26/2012 2:46 PM
Have a look at the manufacturers plate on the transformer. All the information will be there.
03/26/2012 2:51 PM
He doesn't have a transformer, he has a text book.
Good Answers: 181
03/26/2012 9:48 PM
Suppose I was hoping for a bit to much for it to be a real question with a real transformer
03/26/2012 9:05 PM
he has a text book Oh no. He wouldn't do that would he?
03/28/2012 10:21 AM
Normally if it has an OLTC it is the figure given against the centre-tap. What does the nameplate say?.
pnaban
Register to Reply 7 comments
lyn (2); nobodysomebody47 (1); pnaban (1); TonyS (2); wareagle (1)
