Hello I wanted to ask for a supplier of chilled water coils to be installed in a HVAC duct to reduce temperature of outdoor air I need a coil that can handle 75 gpm of CHW @45ºF... Anyone who knows which company I can contact??
Tu conoceras la Verdad y la Verdad te hará Libre......Jesus
A google search in your particular area of the world should show the companies you seek. I would add however, that you ask the selected company to "design" the coil for you. It`s important you not only get the right physical size, you must also consider the pressure limitations both fluid and air side, the pressure drops of each side, and the temperature reduction/ increase you seek on both sides.
http://www.usacoil.com/index.html
If you know some info on how coils are made, this company does have free software to develop a custom coil spec for particular applications.
What type of 7 cylinder radial engine is on your photo? And what is the aircraft?
