Previous in Forum: CR4 Daily Digest The Brain Strainer   Next in Forum: Chilled Water Coil Quote
8 comments
Who Knows The Name Of The Shaft Coupling?
03/28/2012 11:08 AM
If you born poor its not your mistake but if you die poor its your mistake
Pathfinder Tags: coupling
Re: WHO KNOWS THE NAME OF THE SHAFT COUPLING?
03/28/2012 11:20 AM
Oldham coupler, it appears to be. The top image indicates the shafts are not in line with each other.
(I am hoping this isn't homework, I may have chimed in too quickly)
03/28/2012 11:27 AM
it is not oldham coupling.An Oldham coupling has three discs, one coupled to the input, one coupled to the output, and a middle disc that is joined to the first two.Fig is below
03/28/2012 11:34 AM
Yes, there are three discs shown in your image. It appears the shafts do not align. This is (appears to be, anyway) an application for an oldham coupler.
Do the input and output shafts align?
03/28/2012 11:41 AM
No it consist of 2 set of flange and in between them a spider is placed and both the set of flange in different shape.1 set of flange consist of 2 flange and the other set is consist of 1 simple flange and the other one is in convergent shape.
03/28/2012 11:49 AM
"...and in between them a spider is placed..." I can't imagine the spider is very happy about that!
Spider? As in jaw coupling?
I don't feel like playing twenty questions today. Somebody else will come along and play with you. Good luck.
03/28/2012 12:18 PM
Any way thanks 4 trying.....
Re: Who Knows The Name Of The Shaft Coupling?
03/28/2012 6:17 PM
John! That's John Shaft. I'd recognize him anywhere.
Geez, I Haven't seen him since 1973. http://en.wikipedia.org/wiki/John_Shaft
04/01/2012 11:08 AM
Are you sure it's not his cousin Jack. It sure looks like Jack Shaft. ;)
Register to Reply 8 comments
Doorman (3); phoenix911 (1); rajesh1986 (3); Usbport (1)
