Previous in Forum: Crushed Fire Bricks   Next in Forum: Practical Applicability of Plate and Frame Heat Exchangers
9 comments
Vintage Craftsman Drill Press Rust
03/29/2012 1:11 AM
What should be used to remove surface rust from a Craftsman Drill Press Stand model 335.25926
"The way lies at hand yet it is sought afar off; the thing lies in the easy yet it is sought in the difficult"
Re: Vintage Craftsman Drill Press Rust
03/29/2012 1:35 AM
I would use a metal polish, but really depends how deep the rust is....or buy one without rust...
03/29/2012 1:49 AM
I purchased it on eBay and received it today.The drill brackets are covered in surface rust.I have Birchwood Casey metal polish for my hunting gear,I'll give it a try.Thanks.
03/29/2012 2:10 AM
try steel wool and light oil.
03/29/2012 9:15 AM
Use naval jelly, obtain at any paint store.
Your gun gear will have little effect on the rusted drill parts.
Good Answers: 179
03/29/2012 9:27 AM
Two products come to mind regarding rust removal from cast iron and steel:
Eastwood's "Rust Remover". I find that their gel product works the base on vertical surfaces.
www.eastwood.com
The other is Evap-O-Rust, which you can purchase at Home Depot or Lowe's and is significantly cheaper than the Eastwood products, but you need to soak the rusted parts in some sort of container. A gallon of this will cost slightly less than $23, depending on where you're located.
They work and will help prevent/minimize further rust formation. I use both all around the house and on my vehicles here for the last 3 years of so. I swear by these products!
Popular Science - Cosmology - New Member Engineering Fields - Civil Engineering - New Member Engineering Fields - Nuclear Engineering - New Member United States - Member - New Member
Good Answers: 38
03/29/2012 11:04 AM
I use automatic transmission fluid for all my rust removal needs. The stuff is fantastic!
Sometimes my thoughts are in a degree of order so high even I don't get it...
03/29/2012 11:09 AM
I have that in the garage.Thanks.
Good Answers: 19
03/29/2012 11:21 PM
Be careful with the ATF. I recently saw a warning that under certain conditions of heating, ATF can form phosgene gas, similar to WW1 chemical attack agents.
03/29/2012 11:36 PM
Thanks for the heads up.
Register to Reply 9 comments
Anonymous Poster (1); BONVI (3); CaptMoosie (1); ChaoticIntellect (1); Doorman (1); Ried (1); SolarEagle (1)
