Previous in Forum: touching phase lines   Next in Forum: 15-A 220-VAC Fuse for an AC-DC Power Supply
Imbalanced Load for a Double-Wound Transformer
05/08/2007 2:35 AM
Double winding Transformer
I/P = Delta
O/P= Delata & Star
Load on O/P
Delta= 430 Amo
star = 230 ampre
O/p is rectifief by 12 pulse rectirire & both in paralell
please justfy the resion of imbalance on o/o load
Re: Imbalanced Load for a Double-Wound Transformer
05/09/2007 5:45 AM
Are your inputs adequate?
Are all your output rectifiers working?
Specify what you are doing a little better
05/09/2007 9:39 PM
In parallel you should have exactly balanced O/P Voltage. If a slight difference is there sharing will be accordingly
Register to Reply 2 comments
