Previous in Forum: Transformer Oil BDV   Next in Forum: How to Rewire 3-phase 240VAC Resistive Device for 240 Single Phase Power?
Voltage Solution
04/01/2012 10:15 AM
how can i get different volt (6v, 12v, and 24v),dc adapter. and also i need to connect it 12v battery for alternative supply . adapter should work to charge battery and supply dc current in same time(any volt) and this battery should give 12v if electricity stop plz help me friends.....
Re: solution
04/01/2012 10:24 AM
Hire a local electrician or electrical engineer to look at your set up. They will be able to discern all of your available power sources, electrical loads and a myriad of other concerns about your environment. This will be faster and far safer than us trying to educate you here so you can do this yourself.
Re: solution
04/01/2012 11:30 AM
lyn (1); redfred (1); SolarEagle (1)
