Previous in Forum: Combining AC Voltage and DMX Control in One Cable   Next in Forum: Voltage Solution
Transformer Oil BDV
04/01/2012 1:57 AM
What will happen if Transformer oil BDV is low?
Please suggest me all cosequences.
Re: Transformer Oil BDV
04/01/2012 2:14 AM
India - Member - Justin Anto Engineering Fields - Electrical Engineering - Marks never made me laugh, but good memories did
04/01/2012 3:25 AM
Means insulation is less. It will lead to breakdown and dcomplete failure of equipment.
If you can't find a way, make one........
04/01/2012 8:32 AM
Charlie don't surf.
04/02/2012 3:32 AM
Good Answers: 170
04/02/2012 10:25 AM
You can celebrate Diwali at site.
04/03/2012 5:30 AM
This also insulation - reduce over heat. not advisable less than specified
07/17/2019 6:38 AM
The transformer oil is used in the transformer for insulation as well as for cooling purpose. The low value BDV of oil means the transformer oil has moisture in it.The Transformer oil is hygroscopic in nature and it absorbs moisture quickly.The silica gel is filled in the breather to absorb moisture and moisture free air can only enter in the transformer conservator tank.
The minimum BDV value of transformer oil must be 30KV/ mm.
If transformer is operated with oil of less BDV, it is apt to fail. The breakdown of the transformer oil cause permanent damage to transformer. Therefore, the BDV value must be checked to ensure trouble free operation of the transformer.
Read More:BDV of Transformer oil
electricalexpert65 (1); justinanto1987 (1); nobodysomebody47 (1); PWSlack (1); Rajesh52 (1); sridharganasen (1); stevem (1)
