Previous in Forum: Pressure Vessels_Head Calculation_ASME VIII Division 2   Next in Forum: Capacity of Air Compressor
Pipe Wall Thickness Calculated For PMS
04/04/2012 5:11 AM
Hi Friends,
At present, we have flare line in a project with following table design condition:
Pipe
Size
inch
D mm
th mm
Material
T
°C
P
kPa
SE
kPa
y
521321.09.53A358-304L-196\2001,100115,1430.4
Our PMS selection classes for this line indicate thickness about 17.48 mm but calculation by ASME B31.3 has 9.53 mm thickness for this line, our service is cryogenic,
Calculate:
tm=1100*1321+0 mm
2(115143+1100*0.4)
tm=6.29 mm
T=tm+0.125 tm
T=7.076 mm
WALL THICKNESS= 9.53 mm
I think wall thickness calculation by ASME B31.3, cannot base for PMS and that will be minimum pressure design and we must be considered weight load of pipe and ….
Please if experience or exact information source you have, discuss here…
Thank you,
Re: Pipe wall thickness calculated for PMS
04/04/2012 6:38 AM
PMS?
04/04/2012 6:41 AM
Dear SolarEagle,
PMS is Piping Material specification,
04/04/2012 10:26 AM
Thanks for clearing that up.
http://www.acronymfinder.com/PMS.html
Re: Pipe Wall Thickness Calculated For PMS
04/04/2012 6:29 PM
Well I'm just guessing here but 9.55 looks like standard rating, 17.48 looks like maybe schd 80 or thereabouts....You could have calculations on two different materials for your pipe...One more expensive lighter stronger alloy, and one heavier weaker cheaper steel....Why not check with the design engineer and see....
04/15/2012 8:39 PM
Spam: This post was deleted because it contained advertising outside the Commercial Space forum. Please review Section 14 of the CR4 Site FAQ about advertising.
jackchen (1); PWSlack (1); sasan330 (1); SolarEagle (2)
