Previous in Forum: Installing a New Deep Cycle Battery   Next in Forum: Permeability vs Temperature of Electrical Steel
MV Bar Isolation
04/05/2012 2:50 AM
Hi all,
I am looking for a product that is isolates the medium voltage ( operating voltage is 31,5 kV ) electric bur against to the touching.
Do you know a products that stisfy our corresponds our need?
Best Regards,
Musa UÇAN
Unbalance Fault
Re: MV bar isolation
04/05/2012 3:11 AM
<deleted>
04/05/2012 3:39 AM
I didn't understand what do you mean?
Unbalance Fault
04/05/2012 4:27 AM
The comment has been deleted as, in the username owner's opinion, having posted it, it added nothing useful by way of assistance within the 15 minute time-out for editing posts by registered usernames, to the orignal poster's plight.
04/05/2012 7:13 AM
Have you seen transparent insulating material used as protective shield inside switchboards?.
pnaban
Good Answers: 131
04/05/2012 8:05 AM
Tycho Electronics (Raychem) makes a heat-shrinkable tubing rated up to 36kV for bus bar insulation. You slip it over the bus bar and shrink it with a heat gun or propane torch. See the following link:
http://www.gvk.com.au/pdf/heatshrink/high_volt_protection.pdf
They also have it in the form of a tape called HVBT that can be applied to unevenly shaped objects (bus joints, bends, tees, etc.), and is heat-shrunk the same way. My company uses this very often for insulating HV cable to bus connections or cable to transformer bushing connections in place of hand-wrapped tape.
04/05/2012 8:53 AM
Thank you very much Peter.
I called them ( www.raychem.com ) . They have provided a solution tu us.
Best Regards,
Musa UÇAN
Unbalance Fault
Register to Reply 6 comments
M.UCAN (2); PeterT (1); pnaban (1); PWSlack (2)
