Previous in Forum: Lining By Asphalt   Next in Forum: Structural Design
12 comments
Long Span
04/05/2012 11:56 AM
I WOULD LIKE TO DESIGN A HUGE HALL WITHOUT COLUMN , WHAT IS POSSIBLE DIMENSION OF IT?
Re: LONG SPAN
04/05/2012 12:02 PM
If this undefined facility has no roof, and only one floor level, you may make it any size you wish without using any columns.
Re: LONG SPAN
04/05/2012 12:09 PM
HOW TO MAKE CONCRETE ROOF FOR ANY DIMENSION , YOU FORGET OWN WEIGHT OF FLOOR?
Good Answers: 141
Re: LONG SPAN
04/05/2012 12:11 PM
How thick your walls will be? Want to stitch some canvas together and blow it upwards?
Plenty of room here
Re: LONG SPAN
04/05/2012 12:15 PM
HIRE A STRUCTURAL ENGINEER.
Good Answers: 61
Re: LONG SPAN
04/05/2012 12:16 PM
Go here and find one you like.
http://www.google.com/search?q=superdome+seating&hl=en&prmd=imvns&tbm=isch&tbo=u&source=univ&sa=X&ei=AMV9T5ujAoTq0gGw-eHSCw&sqi=2&ved=0CDoQsAQ&biw=1024&bih=665
Do it once and do it right
Good Answers: 179
Re: Long Span
04/05/2012 3:19 PM
This looks, smells, tastes and sounds like a homework problem!
And stop shouting at us in capital letters!
Re: Long Span
04/06/2012 12:02 AM
Did you ever hear of geodesic domes?
Good Answers: 179
Re: Long Span
04/06/2012 9:21 AM
There's a lot of factors to consider when choosing a roof structure, as follows:
1. The roof span between supports. Obviously, the longer the span gets the more complicated the structural design becomes.
2. The actual type of rood structure, including it's "self-weight", which is also known as the Dead Load because it's part of the actual construction and doesn't move once installed.
3. Live loads per actual locale. These include: Seismic Loads, Snow Loads, Wind Loads, Rain Loads, and yes, sometimes Impact loads if the roof is a movable type (opens & closes). These loads are dictated by local, state, and national building codes, but in some cases nations in the developing world that don't have or embrace a national building code may use the Unified Building Code (UBC) and/or the International Building Code (IBC)
4. Roof slopes come into play a lot.
5. Building occupancy type and the number of persons served that would be using the facility will greatly influence the design and the design loads.
For long span roofs there are several different type of roof framing structures that can be used, the proper use, and construction of such, are all dependent on the the rood span, loads, roof slopes, and building occupancy.
Long span steel trusses, long span open-web steel joist, air-inflated roof systems, and "space frames" can be utilized. Each has it own inherent advantages and disadvantages.
Soil conditions and groundwater conditions will come into play as well and dictate what type of foundation(s) can actually be constructed based on the roof type and loadings. Again, each has it's limits.
You seriously need to obtain the design services of a Licensed/Registered Architect, Licensed/Registered Structural Engineer (a PE) and a Licensed/Registered Geotechnical Engineer (a PE).
Good Answers: 104
Re: Long Span
04/06/2012 5:03 PM
This one, built in 1965 (Houston, Texas, USA), has 642 ft clear span, 208 ft high. Larger ones have been built since.
Exterior:
Interior:
It could probably be purchased at a reasonable price, since it is no longer used.
Re: Long Span
04/09/2012 4:07 PM
How big is huge?
This does sound like a homework question, can you provide more information including at least an estimate of dimensions and construction.
Re: Long Span
04/09/2012 4:17 PM
Sorry, Jack. You're too late.
The assignment was due to be handed in last Friday.
Good Answers: 179
Re: Long Span
04/09/2012 8:36 PM
I have this bridge ya see, yeah in ahhh Brooklyn, ya see, that's for sale......
Register to Reply 12 comments
bigg (1); CaptMoosie (3); Doorman (2); dvmdsc (1); HASSAN ELRAMLI (1); jack of all trades (1); lyn (1); PennPiper (1); Tornado (1)
