Previous in Forum: IR TEST   Next in Forum: Does a Cable Have Minimum Current Requirement to Conduct
18 comments
Installation of Lightning Arrestor
04/06/2012 2:17 AM
Great engineers i want you to guide me to install thunder arrestor to a farm house beside a big river,this second time thunder has strike the house.guide me how to make the mat.
Re: Installation of lightning arrestor
04/06/2012 2:35 AM
You must pray to great thunder god for mercy....
If that doesn't work then follow linked instructions....
http://www.lightningrodparts.com/installation.html
Reply Good Answer (Score 4)
Good Answers: 19
04/06/2012 11:04 PM
Very good link to lightning system configuration and layout.
04/07/2012 10:13 AM
SolarEagle,
GA from me as I did almost the same on this on our resort and it works very well! we was hit and have ligthning damaged worth of $87,000 desktop,server room equipment, telephone units and 7 laptops etc. last year and after installing it (DIY), based on lightning strike counter hit registered 6th and we don't have damaged so far.
Regards
Roman
04/06/2012 2:58 AM
Move.
Good Answers: 125
Re: Installation of Lightning Arrestor
04/06/2012 10:23 AM
Cotton balls in the ears make good thunder arresters.
Good Answers: 58
04/06/2012 11:47 AM
Cotton balls are OK but try these Lyndoor "Thunder Arrestor/Boom Box Muffs" - be done with those nuisance thunder strikes forever!
Seriously though, try this page.
04/06/2012 1:04 PM
You are baaaaad.
04/06/2012 1:46 PM
Does reading this OP remind anyone else of Kehaar (Watership Down)?
04/06/2012 1:50 PM
If it isn't on the cartoon channel, I don't watch it.
04/06/2012 1:58 PM
It may just be an interesting enough film to keep the boys attention for a while. Pretty good movie, but the book is better (as I recall, anyway. It's been years). If you are a video rental sort of family unit, I would give it a thumbs up (for whatever that may be worth).
04/06/2012 2:31 PM
Ok,
We do pay-per-view but there's a rental shack just down the street.
May give it a spin, thanks.
04/06/2012 10:45 PM
This is a serious safety question.
The problem with lightening is to ground it as soon as possible to a heavy ground.
Taking a ground wire from the roof to the ground is a lot of wire.
Best to ground it to the water in the upstairs toilet tank, thats a very large ground
04/06/2012 11:48 PM
If you have PEX tubing, you have 0 ground potential as most housing today is all PEXO2. Which means a ground plate and bussing and many feet of COPPER, DO NOt Use Aluminum!
"Real Bass Players" do not use picks
Engineering Fields - Systems Engineering - Member for some time now, see my profile.
04/07/2012 5:57 AM
Hi from Sleepy,
I have beeen involved with Lightning protection of many buildings and structures over many years.
Good Lightning Protection requires
1 Good Lightning rod(s).
Various papers talk to radius of the rod tip and, special materials to make the rod especially attractive to lightning strikes. One remedy that has been used is radioactive materials in the rod to ionize the air around appropriately.
Connected via
2 Linked wiring ( avoiding as many bends as practical as the lightning strike when it comes carries many VHF components and these must be minimised.
3 A very good earth.
earthpit as:
http://www.stonetechnicalgroup.co.uk/downloads/typicalearthpit.pdf
Values of earth resistamce/Impedance neeed to be examined in the literature.
The whole to provide a conical cone of protection which should minimise lightning issus to the structure being protected.
The conical zones of protection were superseded by the
electrogeometrical model in the 1980 edition of NFPA 78, an example of the NFPA Technical
Committee on Lightning Protection keeping up with the current developments in the lightning
protection field.
Good Luck
Sleepy
04/07/2012 9:46 AM
From Sleepy,
I have done some more reading which goes beyond my work a day knowledhe so will place it here.
The Wiki: http://en.wikipedia.org/wiki/Lightning_rod
Legrand: http://www.legrand.com/files/fck/File/pdf/Power_guide/EX29011.pdf
There is much, much more. Other references refer to the roliing nature of lightning, how to predict the size of the ball and so on.
I was going to talk about zones of protection but these have been replaced by incorporating an electromagntic model and in one case by offering Rolling models of lightning.
I was trying to offer you references to all of these but my fingers became unstuck (or stuck) as the case may be so I will send this as is and offer to dig further if required.
Good Luck
Sleepy
Lightning rods can have Radio active isotopes included which can make them more attractive to Lightning vis a vis the rest of the structure.
04/07/2012 10:12 AM
04/07/2012 10:18 AM
05/15/2012 3:49 AM
hello mister tunderbolt lol, yes i will give you how to install your lightning arrestor . first get bronce plate 1mters diameters dig a hole bigger than your plate about 12meters deep and get 3 sacks of meduim pulborized charcoal mix with one sack of salt with water or you can pour water after" then put your grounding rod arrestor on ti then pu it back the soil that you dig on the hole to set it up then install your ground wire going to the top of your house with a long wooden post about 50meters long then your ligthing rod arrestor , then you will done and safe
NOTE : THINK SAFETY ALWAYS !!!
i want ot helf piple need assistance and to share my knowleged in technical
Reply to Forum Thread 18 comments
daveca (1); Doorman (2); Jimh77 (1); KJK/USA (1); lyn (4); Ried (1); Roman (1); Sleepy (2); SolarEagle (1); StandardsGuy (2); toink (1); WJMFIRE (1)
