Previous in Forum: coal water slurry   Next in Forum: Worm and Worm Wheel Set
Polymers Strain-Stress Machine
04/06/2012 7:48 AM
hi group, I am interesed in create a strain-stress test machine to measure polimers. Any clue where to start?. I know that several strain gauges are available, but it is only a starting step.
An help is welcome!
Pathfinder Tags: stress machine
Re: Polymers Strain-Stress Machine
04/06/2012 9:23 AM
04/06/2012 9:26 AM
believe me that the cheaper Instron is very far away from my research budget.
04/06/2012 9:42 AM
Well then, it's pretty straight forward.
You need a base and a movable cross head that is driven by some mechanical means. Instron uses a screw drive.
Strain guages to measure stress/strian and precision instrumentation to record the results.
Mechanical Hand-Held Tension Meters, Yarn Tension Meter
Or,
Images of precision fish scales
Maybe you can find a materials test lab to do the work.
04/06/2012 10:45 AM
I forgot to inclure that I can make the structure, with mechanical screws powered by stepper motors, but the hard part to me is the circuit board to control the strain gauges and their connection to a computer softwre.
Good Answers: 104
04/06/2012 12:37 PM
I would
1. 'strain gages for plastics'
2. 'interface strain gage to computer' or 'strain gage bridge circuit to computer'
Good Answers: 94
04/06/2012 2:23 PM
Have a read of this. Strain in plastics can be difficult to measure because the material behaves, well, plastically. It can continue to extend with no increase in load.
Good Answers: 58
04/07/2012 8:55 AM
This happens in metals and minerals also. It is called CREEP. Even materials that are normally considered totally elastic exhibit CREEP to some degree. If op can't afford an Instron or equivalent machine, consider having the work done at an outside lab, or use a different measuring technology such as photo-elastic.
Register to Reply 7 comments
bigg (1); Fundacion (2); lyn (2); Nigh (1); welderman (1)
