Previous in Forum: Does a Cable Have Minimum Current Requirement to Conduct   Next in Forum: Wire Color Code
How to Troubleshoot a T12 Fixture?
04/06/2012 10:02 PM
I have a T12 fixture that the ballast was recently replaced in get hit with a football and now it won't work. How should I go about troubleshooting it to find the problem?
Re: how to troubleshoot a t12 fixture?
04/06/2012 11:38 PM
Just replace it.
04/07/2012 12:20 AM
t-12's are being/have been, phased out, the t-8's are the new, more efficient, longer lasting replacements....
04/07/2012 1:12 AM
40 W TL (T12) --> 28 W T5 ( Saving Potential-50%)
Payback ranges from 7 months to 1.5 year depending on opration....much worth it.
Re: How to Troubleshoot a T12 Fixture?
04/07/2012 11:18 PM
make sure you turn your breaker off that supplies power to this light fixture.
most likely one of the wires in the tombstone came undone there should be 2 wires connected on each tombstone (thats what the white plastic is called that holds the bulb on the end) on a floresent lamp each bulb has 4 metall pins ( 2 on each end ) all 4 of those have a single wire going to the ballast. one side of the bulb will have 2 yellow wires and the other will have 2 blue wires, if it is a 2 bulb T-12 fixture it will also have 2 red wires, and another set of 2 yellow wires just make sure all those wires have a good connection in the tombstone.
it could also be a broken tombstone they cost about a dollar if that.
but i can only agree its easy to replace the ballast with a new T8 ballast.
this way you don`t have to replace the tombstones, if you switch t5 the bulb lenght is not the same you will have to replace the tombstone holder plate as well.
the best thing is just to replace the complete fixture and not have to worry about anything this is my recommendation anyways.
most those T12 have completed the life cycle and the T12 lamps will not be avail. much longer anyways its time to upgrade to a newer fixture. I would just go and buy a new T5 but make sure to buy a daylight color bulb not a 4100K lamp or even 7000K lamp. this is the color of the lamp you would want something that is good on your eyes not super cold blue and bright.
mciceteade@gmail.com
04/09/2012 11:30 AM
I presume the T12 fluorescent lighting is a Rapid Start system, the one with no
blinking starter circuit involved. Replace all the tube holders as well. If you can afford it, replace the whole thing with a new 40W CFL fixture with a cool white spiral tube.
abele (1); Anonymous Poster (1); lyn (1); onealternative.us (1); SolarEagle (1)
