Previous in Forum: Design MCCB Coordination Parameters   Next in Forum: Mineral Oil Insulated Transformer Installation
RTDs of HV Motor to VSD or MMS?
04/09/2012 6:54 AM
Hello all, there is a HV Motor (6.6kV, 1500kW) which drives a Centrifugal Pump. The Motor is operated by a Variable Speed Drive (VSD), and as per API 670 the Pump is having a Machinery Monitoring System (MMS) as well. Now, where would the RTDs from Motor Windings (6 Nos.) and Motor Bearings (2 Nos.) be connected, at VSD or MMS? Thanks in advance to you all.
Re: RTDs of HV Motor to VSD or MMS?
04/09/2012 7:41 AM
Well, that would depend on the wiring diagram for the panel, Captain. Any chance you could share it with the forum using the green camera button?
Good moaning!
Good Answers: 804
04/09/2012 11:14 AM
RTDs require a specific type of input monitor device, i have never seen a VFD that has that capability buit in. Usually the VFD will also have a Motor Protection Relay (MPR) associated with it and that is what will have the RTD input capability associated with it. Not knowing exactly what your MMS consists of, I can't give you explosive advice, but if it has an option for RTD inputs, that would be my choice.
04/10/2012 6:09 AM
Go through VSD cataloque to see whether facilities are incorporated for connecting the 2 RTDs
pnaban
Good Answers: 804
04/10/2012 10:09 AM
He has 8 RTDs
04/16/2012 9:47 AM
Normally to MMS if it has provision to receive RTD inputs.
Crabtree (1); JRaef (2); nesubra (1); pnaban (1)
