Previous in Forum: 65 MPG Split Cycle Engine the Next Big Thing?   Next in Forum: Make Golf Carts Faster
Mig Welding at Nitriding Material
04/09/2012 8:32 AM
Dear All,
we are trying to mig welding at the nitriding material.but there are very heavy sptter during the welding process.The another observation is crack problem after welding process.The process prameter & material specification is given below.
material 1 -
SAE J2340 420 XF STEEL WITH 2.0~2.2 THICKNESS
GAS NITRIDING SPECIFICATION ON MATERIAL 1
SURFACE HARDNESS Hv (0.1) 35 MIN
COMPOUND LAYER THICKNESS 10µm MIN
DIFFUSSION ZONE THICKNESS 0.45 MIN
material-2
ring gear SAE 1045/ 1050 ( THICKNESS 10 MM)
WELDING PROCESS PARAMETER
CURRENT 140 amp
voltage 14 volt
gas - no gas using
wire thickness- 1.2 mm
tip distance - 3~7 mm
welding wire specifiction
SFA/ AWS A5.20;E71T-GS
Manufacture -ESAB.
KINDLY HELP.
Re: Mig Welding at Nitriding Material
04/09/2012 4:28 PM
Your process says no gas.
You MUST USE A SHIELDING GAS!
Do you know what MIG welding is?
04/10/2012 12:01 AM
yes i am very well know the nig welding but when we use the flux coated wire for welding there are not any use of gas.
while i have tryed the gas at this process also ut result is more bad.
any other idea?
04/10/2012 12:03 AM
What type of shielding gas did you use?
04/10/2012 8:06 AM
i have not useing any types of gases.their are flux coated mig welding wire.
Good Answers: 29
04/11/2012 8:32 AM
I'm pretty sure you mean flux cored wire.
At any rate; you will probably have to preheat the base metals to 400 degrees F. The cool down should be controlled at a rate of about 50 degrees F/hr.
If this is for mass production, it will surely slow you down. Can case hardening be performed after the weld is made?
Si vis pacem, para bellum
lyn (2); PMoon (1); sudheer.singh (2)
