Previous in Forum: Mig Welding at Nitriding Material   Next in Forum: Compression Ratio for CNG Engine
28 comments
Make Golf Carts Faster
04/09/2012 9:20 PM
To make a Golf Cart Street Legal the speed has to be more then 35 mph How can i accomplish this Yamaha g22e goes 14 mph
Re: Make Golf Carts Faster
04/09/2012 9:24 PM
The same way you make a Yugo faster. Find a suitable cliff and...
Sorry but I just couldn't resist.
04/09/2012 9:34 PM
Put some really big tires on the back?
Re-wire the batteries?
Get a real job?
I used to have a gas Yamaha golf cart. It would FLY, after I tweaked it.
Good Answers: 918
04/09/2012 9:35 PM
You a lot need more than just speed to meet requirements for anything beyond Neighborhood Vehicle status.
04/09/2012 9:38 PM
In a hurry?
Sorry, your grammar is usually impeccable.
Good Answers: 918
04/09/2012 10:05 PM
Wow! I have seen that happen before when I try to edit a sentence, it transposes sections of the sentence where it should not be.
You are right. I was in a bit of a hurry and did not proofread the post first. Funny. :)
04/09/2012 10:08 PM
Some guy once told me about a "keypad blocker" that would keep that transposition from happening.
Good Answers: 918
04/10/2012 6:57 AM
Like disconnecting it?
04/09/2012 9:39 PM
Hmmm....
04/09/2012 9:43 PM
Does that truck have a flat tire?
04/09/2012 9:46 PM
That's what really makes the picture, for me...
04/09/2012 10:05 PM
It would be even better then if he was backing off.
What about a Dodge pickup with a Fiat 500 in the bed as a spare vehicle.
04/09/2012 10:35 PM
Being a 48 volt system its likely that it has the power to go 35 MPH so the speed is most likely limited by the speed control box.
Bypass it with a big contactor and see where it tops out at. Next would be to change the differential ratio to a lower ratio. Last would be to add more battery voltage to it and over run the motor.
For someone who has supposedly been building EV's for a while this should be rather basic design knowledge by now.
Service manual link. http://www.used-golf-cart.com/Docs/Manuals/Yamaha/Yamahag22Elec.pdf
04/09/2012 11:44 PM
For speed, replace the controller, the motor and change the gearing, replace the brakes, etc. Also changing to a lighter sealed battery pack would help.
Given the construction of the golf cart I don't think you can meet the requirements to make it street legal unless you have a lot of time and money. Even then it wouldn't be safe either due to the steering and the suspension both of which are not designed for street travel or this sort speed.
In the end you would be better off using parts out of the golf cart to make an entirely new vehicle.
Short answer - no, you cannot make the G22-E a 35 mph street legal vehicle.
Jack - I read the G22-E Manual, did you?
Good Answers: 266
04/10/2012 10:37 AM
A lot of the golf carts the speed is governed by the gearing. They don't want them to go fast, as they can be top heavy. Additional speed may cause them to to roll when cornering. The front suspension will not handle the additional speed for long.
Once got call for service many years ago. They had bought 4 new battery powered industrial electric vehicles. Very similar to golf cart. Maintenance had made modifications so they would go faster at the request of supervision. They wanted to be able to cover the large complex faster. Night crew had been racing them on the company's access to airport runways. Steering failed on one crashed into another and to avoid hitting them the third cut hard and rolled it.
So I would not modify one for speed.
04/10/2012 11:38 AM
Trying to defeat a Darwin award recipient leads to a dumber population.
Good Answers: 59
04/10/2012 10:45 PM
There is a 2 seater mini car, street legal. It can park in a tiny space, crosswise. The name escapes me right now. Check out the Consumer Test Report, and the Highway Safety Institute for its report on it. Does not make the list anyway. It is demolished in any collision, and flies like beachball, with you in it. Unless having an urgent death wish, what about gardening, or origami rather??
04/10/2012 11:12 PM
http://www.villagesgolfcartman.com/
04/11/2012 12:29 AM
Well there you go, best to let the professionals custom build street-legal versions than try and modify something that is designed and priced for a golf course.
Still wouldn't trust it on the road, but if you live in a quite neighborhood and don't have to take the freeway to get to the golf course all you have to worry about is getting squashed by a passing SUV.
Jack - Lives in a quite neighborhood next to a golf course, and no I wouldn't buy one.
04/11/2012 1:12 AM
Buy one of these and put your golf cart body on it....?
Good Answers: 76
04/11/2012 1:35 AM
Not necessarily true; depending on where you live, the laws are slightly laxer in regards to the legality of driving Golf Carts on the street and there is no speed requirement.
In areas with a high density of golf courses, such as coastal South Carolina, where I use to live, the courses update their fleet regularly; so there is a huge supply of used vehicles.
Local towns, (Surfside, Murrels Inlet, Myrtle Beach, etc) allow the use of golf carts on local and secondary streets, without modification, with restrictions... daylight hours... within a certain vicinity from your home, etc.
So, the only way to make your golf cart street legal... cost effectively... is to move to a location that allows them to be operated as is.
04/11/2012 2:19 AM
Try Buggy Works one of the salesmen there was drag racing one for the last 3-4 years. The last time I was ordering parts for our g2 Yamaha he told me he had been getting around 95 mph and was on a hunt for lighter batteries and more voltage as he was running 96 volts then and was trying to get to 100 mph. He may have eclipsed that mark by now. you will have to go to wider and taller tires to accomplish your goal as well as add lighting and turn signals to be road worthy but depending on the area you live that will only allow you on secondary roads not primary or main streets. You can change the batteries to LiPo and go with more watts and volts as well as a different motor. There are motors designed for torque and rpm or just torque with a lower numerical gear and taller tires, but that adds another problem to the works as the controller will probably overheat if you spend any time at part throttle. They have a few controller that are matched to the motor and tire combos just for those problems. on the older resister controlled carts they can handle a little more voltage with out a lot of changing of parts other than the motor or voltage they will be a little more forgiving and handle the heat and a small fan on the components doesn't hurt either. Ask me how I know! My current club car is using 22 inch tires on the front and 24 inch on the rear. I haven't had any problems in all the time I have been running it that way and I am running on 56 volts. that is seven-8 volt batteries and not a foul up yet and it will run almost but not quite 50 mph. and it is stable enough that my wife thinks it is a billy goat and tries to use it to go down into the creek beds and collect large rocks for her rock garden. Before this cart we usually had to go collect her and the Yamaha with the 9N tractor that is why I built the club car as well as it was free and in pretty good mechanical condition.Duke
04/13/2012 10:17 PM
Thank you very much for your info, and i'm glad someone is not a clown.
04/13/2012 10:32 PM
And adding no funny comments really brings out the comedians. its just to easy for them to not take a shot when you give them a chance. If it wasn't for those comments I probably wouldn't have any fun tonight.
Good Answers: 918
04/14/2012 7:08 AM
The reason everyone is a clown is because the idea that simply bumping the maximum speed of a golf cart will make it street legal is totally silly.
While it may be technically possible to jack the speed up, the vehicle would never pass DOT safety requirements (that is an understatement).
If you had done any homework before asking the question you would have never made this post in the first place.
The only workaround is something like Aptera tried by using 3 wheels so that it qualifies as a motorcycle or reduce the requirements so that it has the same status of Neighborhood vehicle (which is essentially a golf cart with all kinds of restrictions).
So, if you wonder why so few people are taking you seriously you only need to examine what you wrote. That's as kindly as I think I can put it.
04/11/2012 7:46 AM
Find a Tesla roadster drivetrain and make suitable adjustments.
Life does not stop and start at your convenience, you miserable piece of..............
04/11/2012 8:32 AM
04/11/2012 11:15 AM
Drop a chevy 350 engine into it.
I went to Texas A&M, I am proud to be an Aggee. Proud to be an Aggey, Proud to be an Agie.............Proud to have gone to Texas A&M.
04/19/2012 9:44 AM
Curious.
Is this to play those golf shots that are out of bound (in the street)? You may also want to invest in an asphalt iron.
Register to Reply 28 comments
Anonymous Hero (4); DGCYS (1); El Duderino (1); jack of all trades (2); JavaHead (1); leveles (1); LOCKDUKE (2); lyn (3); ozzb (1); redfred (4); ronclarke (1); saveone12 (1); SolarEagle (1); szwasta (1); tcmtech (1); Tom_Consulting (1); truth is not a compromise (2)
