Previous in Forum: Blocked Hotmail Account   Next in Forum: [Aeroacoustics] People With Similar Voice
9 comments
Brazing Pinhole Reasons
04/09/2012 9:39 PM
Hello everyone, we have a product that brazed by tunnel furnace. The base metal is brass and stainless steel. The filler metal is brazing pastes: Ag55%Cu Zn sn.Recently, we find some product with pinhole in the brazing joint. The pinhole is bigger and only in the brazing surface of fillet but no in the brazing clearance. You could find it in the photoes. Could you help us analysis the reasons and thanks in advances.
Pathfinder Tags: brazing pinhole
Good Answers: 141
Re: Brazing pinhole reasons
04/09/2012 11:12 PM
Can you re- attach the photos please?
Plenty of room here
04/10/2012 1:07 AM
Sorry for forgotting upload the photo.
Good Answers: 58
Re: Brazing Pinhole Reasons
04/11/2012 9:41 AM
It looks like a gas blow hole. I suspect that you are heating the joint too quickly and a component of the flux is not volatilizing before the braze metal has melted.
04/12/2012 7:20 AM
Try a copper braze ring? Slow the belt speed down? What type of gasses are you using in the furnace?
04/12/2012 9:04 PM
Could we braze brass with copper? Maybe we should slow the belt speed down. Our protect gas is mixture of 30% H2 and 70% N2.
Good Answers: 58
04/12/2012 11:29 PM
Since you are using a reducing atmosphere, you may be able to use a solid preform (washer) instead of the paste. It sounds as though you are using AWS-BAg-7 (56Ag-22Cu-17Zn-5Sn) 1145-1205 degrees f as the braze metal and that should be available in washer form. The advantage of a solid preform is that you won't need to drive off the paste binder.
04/13/2012 12:56 AM
Our filler material is Ag103(EN1044, 55Ag-21Cu-20Zn-2Sn) 1166-1220 defrees f . It is available in washer form but we have use paster for many years. There is seldom have such problems before. Do you think this reasons is filler metal or brazing process.
Good Answers: 58
04/13/2012 8:34 AM
It could be several things including contamination on your piece parts, but my first guess is that some liquid part of your paste is not completely vaporized before the braze metal melts, and the vaporizing paste forces its way through the liquid braze leaving a blow hole. If you replace the paste with a wire preform of braze metal and the problem goes away, you will have solved the problem and lowered cost.
04/25/2012 5:22 PM
sorry for the late post. does the metal have the same properties? the flux?
Register to Reply 9 comments
durtieduck (1); dvmdsc (1); generalee82 (1); lvzhiyong (3); welderman (3)
