Previous in Forum: Why ISO Standards are ISO9001 & 2000   Next in Forum: Sprinkler
Fire Fighting Design
04/10/2012 3:09 AM
Could anyone tell how to begin in designing a fire fighting in commercial or residential buildings? A million thanks to you!
Re: Fire Fighting Design
04/10/2012 3:24 AM
In what country?
What size of building?
To what set of local Building Regulations is the building to be constructed?
04/10/2012 3:58 AM
In Saudi Arabia, just want to know what are those basic things to consider and steps in doing it. A million thanks
04/10/2012 5:16 AM
Then the first step is to obtain a copy of the relevant Building Regulations for Saudi Arabia, and read the section on fire protection.
04/10/2012 8:13 AM
Sir can you please elaborate on what are those next step to do, if you dont mind? A million thanks.
Engineering Fields - Mechanical Engineering - New Member Kenya - Member - New Member
04/10/2012 8:20 AM
I agree with PWslack's approach from a regulation-oriented perspective as Fire Protection standards are stipulated by governing bodies. However, i'd like to add that the two major components of any Fire Protection system are: 1. Detection- refers to thermal sensing systems that initiate an electromechanical signal. Things to consider are the types of thermal sensors e.g. Bimetallic Snap-action sensors that are suited for specific temprature alerts or Rate-of-rise sensors that are suited for applications where it is imperative to send an alert asap without necessarily reaching a set temp. An example of latter would be areas with flammables e.g. gas stations where a sudden spike in temperature is a more important variable than the eventual high temprature. 2. Suppression - refer to extinguishing systems that are activated by alerts from the detection system. The type of fire dictates the type of suppression to be used. Electrical and accelerant fires cannot be extinguished with water, but with wet chemicals or powder or carbon dioxide systems. Hope this helps
Technology solves problems we didn't know existed, or didn't realise that they needed to be solved. Tinkering is therefore never pointless.
04/10/2012 9:24 AM
Thanks bett4haze
Anonymous Poster (2); bett4haze (1); Oje (1); PWSlack (2)
