Previous in Forum: Requirment about Prices ?   Next in Forum: What Is Shrinkage Coefficient?
20 comments
Shower Mud Floor
04/10/2012 10:15 AM
There are radial plastic spokes available to assist with creating a shower mud cement floor. The problem is to get the slope to the center drain correct. The plastic spokes assist greatly with making the mud floor. Otherwise it is a labor intensive and skillful endeavour. The spokes fit around the neck of the central drain and extend to the perimeter of the shower. When installed they have the needed slope. (see below link)
http://www.quick-pitch.com/quick-pitch.html
They are being sold extensively. I am considering using them, but I have heard it predicted that the cement will subsequently crack along the lines of the plastic spokes.
The person making this prediction has extensive experience in tiling and shower making, but has no data to support his prediction.
Any thoughts on the use of plastic spokes,
Angus
Re: Shower Mud Floor
04/10/2012 10:38 AM
Each spoke represents a weak seam in the mix. I think it will crack.
04/10/2012 10:39 AM
I've never used them, but it looks like a good idea.
The spokes look to be like an "I" beam construction. I could see potential cracking problems if air pockets are left under the upper lip, but it seems like if you make sure to trowel the concrete back and fourth, (perpendicular), over the spokes and fill all voids, you should be fine.
Another thought would be to use the spokes to get the proper angle, pull them out while the concrete is wet, and fill the voids that they left.
Good Answers: 58
04/10/2012 10:57 AM
I agree, I think it will crack after time.
Hey....how about one of these pre-manufactured shower pans?
No cement, no concerns about slope, they are strong, no muss, no fuss!
Try this link.
Good Answers: 29
04/10/2012 11:25 AM
You will have cracking especially in the area close to the drain where the width of the slab is reduced by the geometry of the radiating spokes. I never allow a floor/deck slab to have any dimension less than 6" in any horizontal plane (not depth), and 12" is preferred.
Si vis pacem, para bellum
04/10/2012 11:43 AM
Are you still working on this?
Agree with the others, it will probably crack. Is that a big deal? After curing, tile it. Beautiful and watertight. And best of all, it is finished.
04/10/2012 12:23 PM
Each plastic spoke has holes in it to allow the concrete to be pushed through in the horizontal direction so that the concrete is connected between adjacent radial spokes.
Is there any first hand experience out there on observations of cracking along the spokes? What I am hearing is predictions,
EMIL
04/10/2012 12:31 PM
Ciao, adieu, au revoir, adios, guten tag, BCNU.
04/10/2012 1:06 PM
None here. Bye.
04/10/2012 1:26 PM
Hmmm, then maybe in your original post you shouldn't have said...
"Any thoughts on the use of plastic spokes",
I think you've scared away the natives now.
Good Answers: 120
04/10/2012 10:43 PM
I looked at the demo video, and it appears to me that if you make sure the holes are filled that tie the mud into a solid mass through the tapered stick then you will have a floor that is stable, as long as the floor beneath is has the needed rigidity. I say this because they seem to have about 60% free space in the holes, which will make a solid base as long as the mud is fully flowed through the holes. Remember, cement is brittle, so it is critical that the sub floor be rigid
Per Ardua Ad Astra
04/11/2012 8:26 AM
thank you for your comment about the holes in the plastic spokes. the subfloor was mud prepared from sand topping mix plus sand (ratio 2, 1). it is stable.
Angus
04/10/2012 11:23 PM
Add a plasticiser and waterproofer to the cement mix to reduce the likelihood of cracking.
Madness is all in the mind
04/11/2012 8:11 AM
Dear Fellow Scot: Thank you for thinking about this problem. They sell mud components here (Washington DC area)that recommend adding latex emulsion, which is also provided. This will provide extra strength and enhance waterproofing to the cement. Would this be a positive or negative from cracking standpointment? Does it conflict with additon of plasticiser?
Now regarding plasticisers what would you recommend and how much?
Angus
04/11/2012 1:26 PM
I've only done this DIY - and found using washing up liquid (15-20ml per 30kg mix) a good basic plasticiser! Now whether you would want to try that, or go for one the mud supplier would recommend is up to you.
04/12/2012 12:56 PM
Cool new idea, a floor that foams.
Good Answers: 179
04/11/2012 9:37 AM
I've used the Quick-Pitch product before with satisfactory results. But you need to do a few things to minimize shrinkage cracking in the cement bed:
1. Don't install a slab any less than 4-inches in minimum thickness.
2. Don't remove the plastic "spokes". Leave them in place, otherwise you will be inducing weak plane in the cement bed.
3. All cement and concrete shrinks, no matter what you do. But you can minimize shrinkage cracks by using a low "Water-To-Cement Ratio". I recommend not exceeding a 0.40 W/C Ratio....which is measured by the weight of the cement to the weight of the water. Too much water will induce higher degrees of shrinkage which is something you do not want with a shower stall floor because it'll leak like a sieve. Use a Mid-Range to High-Range Superplastizer and follow the directions to the T. DON'T OVER DO IT! You will not need much with the volume of cement you'll be placing. Plasticizers allow you to "juice-up" the cement mix for easier workability and increased set time without the need to add more water which is detrimental to concrete strength and durability.
4. After the cement bed has set sufficiently (see no thumb prints, etc), install a 6 mil poly plastic sheet over it and make sure you tape the edges of the sheet so that it'll retain moisture under it, thus aiding in the cement curing process. This is critically important. Make sure this plastic sheet remains in place at least 7 days.
Or, you can flood the cement bed when it is safe to do so and not degrade the cement surface, so as to provide an excellent curing environment. Make sure you do this and maintain it for at least a week.....add water when necessary and don't let the cement surface become dry. A few inches of standing water is all you'll need.
5. Following the 7 day curing period, seal the cement surface with a high quality concrete sealing compond. Don't use Thompson's Water Seal because it's useless. Use a quality construction grade concrete sealer that PENETRATES. You can also apply asphalt paint to the cement surface. make sure you buy the stuff intended for concrete foundation wall applications that actuallly does air-dry.
Or purchase a plastic shower stall base!
04/11/2012 2:21 PM
Captain: Thank you for your thought-provoking comments
"1. Don't install a slab any less than 4-inches in minimum thickness."
My shower has a prepan that is made from Sand Topping mix:Sand (2:1) and is around 2 1/4" in depth. It sits on top of metal lathe that sits on top of foofing felt. Below the roofing felt is the plywood.
The water proof shower liner sits on top of the prepan and is secured to the studs all the way around the shower.
What I have in mind for the mud floor on top of the shower liner is depth of 1 3/4".
So it will not be 4" in depth.
Water can seep through the mud floor and reach the liner and is removed by the weep holes at the drain.
That is what I have. So now that I have given this informtion can you reevaluate.
Angus
Good Answers: 179
04/12/2012 8:39 AM
Hello Angus,
I didn't realize you had a liner and the weeps, so you're slab thickness should be more than adequate IMO. Just make sure you don't plug-up those weep holes!
Good luck with your installation!
04/12/2012 10:07 AM
Thank you Captain for taking the compass coordinates: my own feeling is that we are in uncharted waters here. I am thinking to include acrylate emulsion in the cement mud, since this is a polymer and it will act as a plasticiser in the cement. It ought to make the cement floor less likely to crack.
ANGUS
04/12/2012 10:30 AM
"... my own feeling is that we are in uncharted waters here."
You have got to be kidding me.
Register to Reply 20 comments
Angus McLean (5); aurizon (1); CaptMoosie (2); Doorman (3); GM1964 (2); KJK/USA (1); kramarat (1); Leonf (1); lyn (2); PMoon (1); user-deleted-1105 (1)
