Previous in Forum: Laser Communication   Next in Forum: How to Acces Internal ROM in Atmel 89C51?
10 comments
How To Calibrate Biotech Tools and Equipment
04/11/2012 8:21 AM
Hi, its there any idea how to calibrate anemometer, pyle 3 n 1 humidity tester, and tachometer.
Pls. give me an idea.
Morning Shines with spider top of the ricefields, that's where I' m came and I saw life and I missed where I before".I'm swordspider...
Re: How To Calibrate Biotech Tools and Equipment
04/11/2012 8:24 AM
Yep. Read the instruction leaflets supplied with the equipment.
04/11/2012 8:37 AM
ok thanks.But actually this equipment have no leftlits now.
04/11/2012 9:07 AM
If you can find the model number, you can usually find the manuals / "leaflits" online in .pdf forms, or you can contact the manufacturer that produces it and request a duplicate manual.
The first law of thermodynamics is you do NOT talk about thermodynamics.
04/11/2012 9:13 AM
ok thanks sir but I contacted the manufacturer but until now thier is no reply.Can you give me link of the pdf file you mentioned?
04/11/2012 9:29 AM
Do you have a model number / manufacturer name?
04/11/2012 9:44 AM
yes sir but the units deposited in our office.I will sent it or i will post here tomorrow.
04/12/2012 12:48 AM
04/12/2012 9:01 AM
Hi lyn thanks for this offer.I wanted to calibrate this equipment.I need a procedure how?
04/12/2012 11:58 AM
greencomval,
Go to the website I gave you.
If you can find the link below, and open it you will have the manual.
This is very elementary and even my 7 year old can do it.
  • Manuals and Downloads
04/13/2012 10:17 AM
Lyn I'm not looking with the internet tutorials what I mean is that How to calibrate the pyle humidity tester 3 n 1 it is very needed during bidding of machine services.The campany will look of that to assure that our equipment is surely good during troubleshooting and calibration.
ex: How to calibrate analog voltmeter 360 trf
resistance
1. attached the two test probe of the tester
2. As long us the needle move to the right side, use the ohms zero collector switch to set the needle in zero ohms
3. Once the needle position in the zero ohms it is understood that the battery is good and it can perform an exact value of the electronic parts.
If you want to study computer basic just follow this link: http://combinebasic.blogspot.com/.
Register to Reply 10 comments
greencomval (5); lyn (2); Mizuti (2); PWSlack (1)
