Previous in Forum: Overheated Motor   Next in Forum: How To Measure The Flow Of Water From A Peristaltic Pump?
API 620-Cylinder Shell Thickness
04/11/2012 12:56 PM
Dear All,
I have started using API 620 for following tank.
Tank internal design pressure / pressure rating (As per API 620) = 0.8 bar (g)
Tank Diameter = 3450 mm Tank height = 5900 mm liquid density = 920 Kg/m3
tank shell thickness = 04 mm (proposed), Top cone roof thk = 04 mm (proposed)
Now I calculated the 2 forces at a section in shell at the bottom of shell
They are T1 and T2 as per API 620 nomenclature. T1 = 10570 N/mm and T2 = 229 N/mm
When I am using T1 as the largest for shell thickness calculation using Sst = 126 N/mm2 (linear interpolation) and E=.85 the thickness comes too much higher 98mm???
Please help.
Regards
ASD23789
The light of blindness of knowledge is yet to reach me, forget being clever.
Re: API 620-Cylinder shell thickness
04/11/2012 12:57 PM
In continuance with this, i am using edition 2002 with addenda 2004.
Re: API 620-Cylinder Shell Thickness
04/12/2012 12:40 PM
04/12/2012 1:29 PM
I'm not familiar with the terminology of API 620, but something looks odd about the 10,570 N/mm2 number (seems too high).
Register to Reply 3 comments
asd23789 (1); SolarEagle (1); Tornado (1)
