Previous in Forum: Line Voltage Increases While Two Plant are Sync Condition   Next in Forum: Generator kWh Reduces
How to Change Generator Reactance Value to %
04/15/2012 9:58 PM
Hi Guys,
I have currently a generator with me with the reactance in per unit value.
Take for instance, the if Direct axis synchonous reactance is 1.9226 per unit.
Does this means that it is 192.26%?
Please Help !
Thanks !
There is no limit towards how much one can learn.
Re: How to Change Generator Reactance Value to %
04/15/2012 10:50 PM
Good Answers: 170
04/16/2012 9:09 AM
Yes! It does mean that the Direct Axis Synchronous Reactance is 192.26%, which means that the intenal voltage drop within the generator windings with rated load at rated power factor, will be 192.26% of the rated terminal voltage, which also means that the EMF generated by the generator will be 292.26% of the rated termial voltage.
Good Answers: 244
04/17/2012 10:20 PM
The generator reactance is 1.9226 per unit means the calculated per unit value of the generator is 1.9226 with the base value of the generator's rated KVA and rated voltage.
For example, the generator is assumed 5 MVA, 11KV, 3 phase. For this case, the base KVA is 5000 and base KV is 11 (L-L).
For this system,
The base impedance (Zbase) = (Base KV)2 x 1000 / Base KVA
= (11x11x1000) / 5000 = 24.2 ohm
The actual reactance of the generator
= base impedance (Zbase) x per unit value = 24.2 x 1.9226 = 46.53 ohm
Hope it helps.
- MS
Register to Reply 3 comments
electricalexpert65 (1); lyn (1); msamad (1)
