Previous in Forum: Hydraulic Motor Selection   Next in Forum: 50Hz
8 comments
Belt & Bucket Elevator Design
05/09/2007 3:56 AM
Hi,
Can anyone please help me how to design a belt & bucket elevator. Mainly formulae for calculating power required, number of buckets, etc.
Thanks.
Re: Belt & Bucket Elevator Design
05/09/2007 7:50 AM
Start with how much stuff needs shifting, at what rate, over what distance perpendicular to gravity? Of what material and texture is the stuff that needs shifting?
05/10/2007 4:04 AM
I am looking to shift grain with a bulk density of 525 kg/m3 @ 5 Te/Hr to a total height of 25m.
Technical Fields - Education - New Member Technical Fields - Technical Writing - New Member
05/10/2007 8:14 AM
If in Great Britain...search for bucket elevator > get general info from manufacturer
Decide: buy or make your own buckets (it's not so hard)
I guess that your 5 Te = 5000 kg
(5000 kg/hr) / (524kg/m^3) =9.5238 cub meter (m^3) per 3600 seconds or
2645.5 cub cm per second.
Assuming (you may pick up other numbers): 3 bucket per one meter of the elevator belt and linear speed of 10 cm/s.......
Sorry I have to go, I will continue tomorrow if....More questions?
Get dimensions of the bucket
05/10/2007 8:15 AM
This website has some good info on bucket elevator design that should be helpful to you.
http://www.unionironworks.com/indbetipsag.html
05/10/2007 2:53 PM
Marten Sprocket and Gear of Arlington Tx. USA sells elevator components (I have purchased many from them) but more to your question their catalogue has a nice section that can answer your questions such as a power usage table and thruput equations.
Everything I know about opera I learned from Bugs Bunny
05/11/2007 3:43 AM
Thanks for all your help.
Chain type centrifugal Bucket Elevator Design
06/23/2008 5:22 AM
can anyone suggest how to disign the centrifugal chain type bucket elevator ?
01/30/2009 5:35 PM
If you are simply looking for projected horsepower, the formula is relatively easy. You should check with the manufacturer for final, but this will get you close.
This is how I project motor size in the USA.
Capacity in pounds per hour / 60 minutes per hour x discharge height in feet / 30,000 (this is a constant) = ____ basre horsepower x service factor = required horsepower. Round this up to the next largest motor.
AllanT (1); Anonymous Poster (4); DaveB (1); PWSlack (1); southern123 (1)
You might be interested in: Industrial Conveyors, Flat Belt Pulleys
