Previous in Forum: Wet Process Collagen Sausage Casing Manufacturing   Next in Forum: Vacuum Furnace Problems
What Are The Causes Of High Suction Pressure In Ammonia Compressors
04/17/2012 9:24 AM
what are the causes of high suction pressure in plants that use ammonia for refrigeration
Re: What are the causes of high suction pressure in ammonia compressors
04/17/2012 9:28 AM
Vacuum, created by machinery.
What sort of plants use ammonia for refrigeration? Like this?
Re: What Are The Causes Of High Suction Pressure In Ammonia Compressors
04/17/2012 1:11 PM
It sounds like you might have water contamination...run test and remove if necessary.
04/17/2012 11:20 PM
Some possible causes of high suction pressure:
Higher load than usual (e.g., warmer water or product to be chilled)
Not enough compressors running to handle the load
Malfunctioning load/unload valves or mechanism
Excessive clearance (wear) between piston rings and cylinder, or screw and housing.
Location: Oyu Tolgoi Copper Mine, South Gobi Desert, Mongolia
04/19/2012 2:14 AM
Need a few more details - is the discharge pressure normal? I suspect it might be low... (system under-serviced). You may have a leak.
Fluor Corporation
Register to Reply 4 comments
Doorman (1); mechanic58 (1); SolarEagle (1); Tornado (1)
