Previous in Forum: Measure Refrigeration Capacity of a Plant   Next in Forum: Horizontal Split Casing Of Multi Stage Centrifugal Pump
17 comments
Weight Calculation
04/17/2012 9:45 AM
HOW TO CALCULATE WEIGHT IN MS ROD AND COPPER?
Re: WEIGHT CALCULATION
04/17/2012 9:51 AM
  1. Turn off Caps Lock
  2. Open Kempe's Engineers' Yearbook at the materials data pages
  3. Measure the size and shape of the rod so as to obtain volume
  4. Multiply by the density in the materials data pages of the aforementioned publication
Re: Weight Calculation
04/17/2012 10:23 AM
Option 2:
  2. Obtain an off-cut of the same material of which the weight is wanted
  3. Weigh the off-cut and record
  4. Multiply the recorded weight by the ratio of the length of the unknown weight material to the length of the offcut.
04/17/2012 10:25 AM
Option 3:
  2. Obtain 1mm-squared paper and a pencil
  3. Place the paper over the end of the rod and obtain a rubbing of the end, using the pencil
  4. Count the rubbed-in squares on the impression of the rod on the paper so as to obtain cross-section area
  5. Multiply by the length of the rod, so as to obtain volume
  6. Go to #1↑ item 4
04/17/2012 10:27 AM
Option 4:
  2. Obtain the cross-sectional area from the manufacturer's published information about the rod
  3. Multiply by the length so as to obtain volume
  4. Go to #1↑ item 4
04/17/2012 10:29 AM
Option 5:
  2. Obtain manufacturer's data sheet about the rod
  3. Multiply the published weight-per-unit-length by the length of the rod of unknown weight
04/17/2012 10:31 AM
Option 6:
  2. Obtain weighing device suitable for the size of the rod of unknown weight
  3. Tare the weighing device to zero
  4. Place the said rod on scales
  5. Read the weight of the rod from the display on the weighing device
04/17/2012 10:46 AM
Option 7:
  2. Obtain a water tank sufficient to receive the rod of unknown weight fully submerged
  3. Fill the tank to the brim
  4. Immerse the rod in the tank
  5. Collect the displaced water and measure the volume
  6. Go to #1↑ item 4
04/17/2012 10:49 AM
Option 8:
  2. As #7↑ item 2
  3. As #7↑ item 3
  4. As #7↑ item 4
  5. Remove the rod from the tank and observe the drop in level
  6. Calculate the displaced volume from the drop in level
  7. As #7↑ item 6
04/17/2012 2:52 PM
In #7 and #8, I'd advise the OP not to swim in the tanks while performing these tests.
Oh yes. TURN OFF CAPS LOCK!!
04/17/2012 1:14 PM
What's an MS rod ?
04/17/2012 4:04 PM
MS = MILD STEEL (ooops! I had the caps lock on)
04/17/2012 4:07 PM
or, MS=macho street
What's a copper?
Never mind, I've got it. A COPPER is who chases a MS ROD.
04/17/2012 4:22 PM
"What's a copper?"
Two pence, I think. We need to wait for a friend from across the pond for a final.
Or, the old standby answer... About 3-1/2 pounds.
04/19/2012 6:26 AM
It's a UK-based non-derogatory colloquialism for a Police Officer.
04/17/2012 1:16 PM
Psssst.
Mohana, it is probably a good idea to turn off the caps lock.
Oh, and your friend PWSlack has given you the correct answers.
India - Member - New Member
Good Answers: 164
04/17/2012 11:25 PM
With all due respect to the eminent posters, they didn't read the question properly...
First you get into the MS ROD. Then the rod gets into this nosey copper who is doing his beat and gets curious about this MS ROD which is doing St Vitus dance (since you are in it now). And ends up with the rod in his tummy. Now you calculate the weight.
OK, that takes care of the morning blues.
04/18/2012 8:10 PM
1/2" copper rod = .97lb per ft.... 1/2" steel rod is a little bit less.... @.667 lbs per ft...
Diameter in inches squared x 2.67 = lbs. per foot for steel rod
Square of diameter X 9.42 X density of alloy = weight per lineal foot in pounds.for copper
copper typical density .323
density in lbs per cu in
Register to Reply 17 comments
Doorman (3); kvsridhar (1); lyn (2); PWSlack (9); SolarEagle (2)
