Previous in Forum: Appropriate Length of Spoke for 26 and 24 Inch Wheel   Next in Forum: Ariel Compressor Failure
Pipe Failure Theory
04/21/2012 4:12 PM
dear sir/s,
If the internal pressure is the only load that the pipe faces, and the pipe of thickness "t" calculation is satisfied by Von Mises' theory.Then it is obvious that any pipe of thickness less than "t" will be considered as unsafe. But in such a case of a pipe with thickness < t, can you please explain whether or not, this will pass Tresca's theory of failure?
best regards,
Re: Pipe Failure theory
04/21/2012 4:39 PM
Perhaps a quick synopsis of Von Mises' and Tresca's respective theories would help. Or just furnish a set of sample calculations.
04/21/2012 7:54 PM
04/21/2012 11:49 PM
It is also obvious that if you understand the limitations of each of the theories, that you will probably be able to work out the answer - and it is the importance of understanding these limitations, and not the answer as such, that is, I suggest, why the original question was asked.
Re: Pipe Failure Theory
04/23/2012 8:55 AM
Am I right in saying that a real pipe will always have more than just the internal pressure as a load?
04/23/2012 10:14 AM
Yes (e.g. tension, compression, bending from structural loads). Often, but not always, these other loads are much less than the internal pressure load.
IdeaSmith (1); lyn (1); Tornado (2); TrevorM (1)
