Previous in Forum: Install Pulley   Next in Forum: Ward 7D
Gasket Between Volute and Pump Bonnet in Single Stage Overhung Pump
04/25/2012 4:45 AM
HI Guru es,
Can we use a spiral wound ring in tongue and groove joint of pump volute casing. if yes please tell me tightening torque and tightening procedure.
ahb
Re: Gasket between volute and pump bonnet in single stage overhung pump
04/25/2012 4:57 AM
The pump manufacturer can advise all. How about a telephone call to their technical helpdesk, particularly if the thing is still under warranty?
04/25/2012 11:31 AM
sir
Pump is not under warranty.
ahb
04/25/2012 11:58 AM
This fact doesn't stop the thing being the subject of a telephone call to the manufacturer's technical hotline. After all, these people are usually too busy helping out their Customers to spend their time on CR4!
Waiting in vain hope of a reply here must surely be less acceptable than making the call and getting the information straight away?
Sheesh.
Re: Gasket Between Volute and Pump Bonnet in Single Stage Overhung Pump
04/25/2012 9:08 AM
You provide no useful information to help answer the question.
Contact the pump supplier, as PW stated.
04/25/2012 11:21 AM
I have no idea, but as you can see from the three replies you have gotten, actual knowledge and the ability to educate takes a back seat to seeing your name and moniker on CR4. Getting a reply from someone who has actually used a spiral wound ring gasket, or had experience repairing a pump volute casing seems like it might help. In the meantime, look, I got another post!
04/25/2012 11:47 AM
Your useless response adds no value to the discussion. How would you advise the OP, without knowing anything about the pump?
Let's see, how about tighten the bolts in a cross pattern at 75 foot pounds.
I'm outa here.
04/25/2012 12:36 PM
I would not advise him if I didn't know the answer. I've never used that gasket profile or material or repaired a pump volute casing assembly.
Register to Reply 7 comments
arshad bbc (1); lyn (2); PFR (2); PWSlack (2)
