Previous in Forum: How To Make Simple AVR For Generator 1.5 kva 3 Phase   Next in Forum: Brushless Excitation System
Noise In The Laser System
04/25/2012 5:49 AM
We are having laser system.there is noise in the laser system.so anyone can suggest from where the noise is coming .as we have isolation transformer and have earthing.
Re: noise in the laser system
04/25/2012 5:55 AM
It will be radiated or conducted.
An isolation transformer will do nothing to reduce noise, it will go straight through any transformer.
Some filtering on the incoming mains would be a good start.
Analysing the noise is also a good idea, is it a fixed frequency? Pulsed? Regular?Random? in sync with anything operating in the vicinity?
Are we talking megawatts, milliwatts or what watts?
You post is pretty much devoid of any useful info' so it's hard to comment further.
04/25/2012 5:59 AM
To avoid the forum needing to play a game of "20 Questions" in order to assist, please provide a full description of the noise, its characteristics, and the behaviour of the equipment while it is both present and absent. This will enable a quicker solution to be found than going down the "20 Questions" route, and thereby eliminate the trivial possibility of a mouse having made a home inside it, for example, far earlier.
Good Answers: 44
04/25/2012 11:45 AM
I bet its actually a little light bulb that blinks...
04/25/2012 6:30 AM
Register to Reply 4 comments
cuba_pete (1); PWSlack (1); strongcrusher (1); user-deleted-1105 (1)
