Previous in Forum: Design Pressure as MAWP   Next in Forum: Continental Industries Blower
9 comments
Surge Vessel Precharge Pressure
04/26/2012 3:51 AM
Hi guys,
We have running water supply project in GCC included 6 pump stations and 6 nos surge vessel bladder type. Further to surge designer report the pre-charge pressure should be 7.5 bar, 17 bar, 22, 24, and 30 bar.
Is there any limitation for precharge pressure and why?
How to reduce this pressure?
Regards
Ali
Pathfinder Tags: surge vessel
Re: Surge vessel precharge pressure
04/26/2012 3:55 AM
<...GCC...>
Wha'?
<...Is there any limitation for precharge pressure and why?...>
The structural design of the vessels?
<...How to reduce this pressure?...>
Bleed some of the precharge from them?
04/26/2012 4:17 AM
Are each station working at a different pressure?. What are the required pressure of each station including pump start/stop(cut in/cut off) pressure?. Are the rubber bladders and tanks rated for those pressures?.
pnaban
Good Answers: 38
04/26/2012 7:31 AM
What did the vendor recommend when you contacted them ?
Popular Science - Cosmology - New Member Engineering Fields - Civil Engineering - New Member Engineering Fields - Nuclear Engineering - New Member United States - Member - New Member
Good Answers: 38
Re: Surge Vessel Precharge Pressure
04/26/2012 11:20 AM
I've only done a handful of surge tank designs, but a 30 bar preload surprised me. I'm curious, what type of water supply application is this?
Sometimes my thoughts are in a degree of order so high even I don't get it...
Good Answers: 137
04/26/2012 3:39 PM
Precharge pressure depends on the working pressure of the system. Normally precharge to ~ 1/2 the absolute working pressure. Then when the surge vessel sees system pressure the air compresses to 1/2 the vessel volume and you have 1/2 water, 1/2 air in the vessel, usually about right to handle higher and lower pressure fluctuations.
04/26/2012 10:56 PM
Does it(air pressure) have any relationship to the cut-in pressure?. We charge with nitrogen instead of air as air in contact with moisture will corrode the interior of the vessel.
pnaban
Good Answers: 137
04/27/2012 11:13 AM
Yes, you want the cut-in pressure to be above the pre-charge pressure. Then as the system pressure slowly falls, the pump restarts before all the water has left the vessel. If the cut-in pressure is lower, when all the water has left the vessel the pressure falls rapidly to cut-in point, and when the pump starts there is no surge protection till pre-charge pressure is reached, potentially causing water hammer.
04/26/2012 10:52 PM
Hi Ali
1. The initial pressure would depends on the final volume of air that you want it to be in the surge vessel. You can use following equation
Po = P x (V/Vo)
where, Po is the initial pressure, P is the normal operating pressure V stands for volume of air and V/Vo is the ratio of final volume to that initial volume of air inside the surge vessel. Vo = volume of surge vessel.
2. Let say if you want the air final volume to be 1/2 of initial volume (V/Vo = 0.5) than Po = 0.5P. If the final volume is 1/4 (V/Vo = 0.25, water 3/4 full) then Po = 0.25P
3. The above equation is derived from the universal gas law PV=nRT. Since nRT are all constants, pressure is a function of volume only.
04/30/2012 11:34 AM
Project water supply to top of mountain including 5 nos pump station with 2+1 high pressure pumps with FLOW 52 LPS as below Head. DI pipe line by length of almost 21 km
1- no.1 pump station Head 174 mtr
2- 351 mtr
3- 348
4- 411
5- 356
ali
Register to Reply 9 comments
Ali 47 (1); ChaoticIntellect (1); Codemaster (2); MJCronin (1); pnaban (2); PWSlack (1); sabriahmad (1)
