I have a European Standard Induction Motor as rated :
Volt : 380 Vac
Freq: 50Hz
Output: 22kW
Rpm: 1480rpm (4 pole)
In Asia, 3Phase power requirement will be: 415V, 50Hz.
I would like to use this motor in Asia. In my opinion, considering the voltage drop along the line from MCC will reduce the volt to some varies value. Does the value would make the motor run?? Is it run efficiently?? Any other things that we should consider??
