Previous in Forum: Position of Kicker Line on Pig Launcher & Reciever.   Next in Forum: Eccentric Reducer - Reciprocating Pump Suction
CEP
05/01/2012 11:55 AM
Dear sir,
Please confirm my doubt That the suction pressure of condensate extraction pump of a steam turbine is positive or negative pressure.
Rajesh
(inst Engineer)
Re: CEP
05/01/2012 12:11 PM
Well, what happens in the condenser?
Re: CEP
05/02/2012 7:40 AM
Dear sir,
condenser pressure is negative (-0.9kg/cm2) and why the pumps are errected in sump .
Thanking you,
With regards.
rajesh
Re: CEP
05/02/2012 8:19 AM
OK. Well, that answers the originally-posted question.
Because of the low pressure, the pump suction needs to be as short as practicable. Immersing the pumps in the sump itself is about as short a suction as any designer is likely to achieve. The need for a short suction line arises as an attempt to prevent the liquid from boiling at the pumps' inlets and the effects of cavitation occurring on the pumps' impellers. Cavitation in any pump will shorten the life of the impeller appreciably.
There is a good article on cavitation in Wikipedia.
Re: CEP
05/01/2012 12:22 PM
I'll confirm that you appear to have a doubt.
Which do you doubt?
What do you think?
Try this:
About Web Search - Learn How To Search The Web
PDF]
SJD (CEP) Vertical Condensate Extraction Pumps
Register to Reply 4 comments
lyn (1); PWSlack (2); Rajesh nagiri (1)
