Previous in Forum: LED RFI   Next in Forum: Deleted or Wiped
Faraday Cage
05/10/2012 3:19 PM
Can we can make a mobile call from inside a Faraday Caged building? If yes, how?
Pathfinder Tags: Faraday cage
Re: Faraday Cage
05/10/2012 3:34 PM
Stick an antenna through the wall.
If it's a true Faraday Cage, what do you think?
The ways to do this are probably highly classified and not for you to know.
Re: Faraday Cage
05/10/2012 4:53 PM
Sticking an antenna through a Faraday cage breaks the cage. Most buildings designed to be a Faraday cage, do this for security reasons. Most of these secure buildings have detectors inside that notice cell tower communication originating inside the building. Trying to breach building security will get you arrested or fired from your job.
You don't happen to work for Al Qaeda, do you?
Re: Faraday Cage
05/10/2012 7:17 PM
Not easily if at all (depending on the level of building shielding) so leave the building to make the call. If shielding is only light (ie- not a perfect cage) then you may be able to use or (run) a land line through the wall or move to an area where the shielding is the weakest (such as a window) and try there.
Re: Faraday Cage
05/11/2012 7:42 AM
Just as pass by, would like to say that : Answesrs nos. 1 and 3 realybmake sense. but answer no.. 2, probably refers to Potato Chips Packaging discussion and not relevant to the subject.
Re: Faraday Cage
05/17/2012 1:59 AM
no offense intended, but are you in prison?
Anonymous Poster (1); durtieduck (1); jack of all trades (1); lyn (1); redfred (1)
