Previous in Forum: Natural Gas vs. Gasoline: Reduced Efficiency?   Next in Forum: PWHT
Hobbies - Automotive Performance - New Member Hobbies - CNC - New Member
Shell and Tube Heat Exchanger
05/14/2012 2:40 PM
Have you ever heard of a design for a baffle cuts more than 50%?
Can this be considered as a segmental type heat exchanger?
It is better to fail in originality than to succeed in imitation.
Pathfinder Tags: heat transfer
Re: Shell and Tube Heat Exchanger
05/14/2012 9:43 PM
You mean more than 50% of the cross-sectional area of the HX?.
This one has baffles with an area more than 50% of the cross-sectional area of the HX:
Having more than 50% increases efficiency - up to a point.
05/14/2012 10:47 PM
baffle cut meaning the %cut from the total cross sectional area. This one does not look like that..
Baffle cut is the ratio of baffle window height to the shell inside diameter.
05/15/2012 12:06 AM
In this publication, look at heading number 1.2.4.7 (baffles). It should clear things up for you.
This was found very quickly by typing baffle cut in Google.
Are you having trouble searching the internet?
Here is some help:
http://www.media-awareness.ca/english/resources/special_initiatives/wa_resources/wa_teachers/tipsheets/search_internet_effectively.cfm
http://www.internettutorials.net/
http://www.wikihow.com/Search-the-Internet
05/15/2012 12:21 AM
Sir, I don't know what you mean. It is exactly what I said.
Section 1.4.2.7 of wolverine heat transfer data book (which i have read more than four times in the last four years) says "For liquid flows on the shell side, a baffle cut of 20 to 25% of the diameter is common; for low pressure gas flows, 40 to 50% (i.e. close to the maximum allowable cut) is more common, in order to minimize pressure drop"
Now, ignoring you patronizing comments, let us go back to question at hand. Have you ever seen a 75% baffle cut design?
The picture you showed earlier was not 75%.
Thanks. And Lets stay civil.
05/15/2012 1:20 PM
You mean like this PM you sent me?
1534 updated discussions
Home | Mikerho
Write New Message | See inbox & sent mail"Inbox" Message
EconomistPower-User
Join Date: Jun 2008Location: New York, NYPosts: 216Good Answers: 1
Hi 05/15/2012 2:46 AM
To:
Mikerho
asshole!
05/15/2012 3:26 PM
I know how to search the internet.
Register to Reply 6 comments
