Previous in Forum: Help - Need Equation for Round Cantilever Beam   Next in Forum: Control valve flange thickness
Good Answers: 101
Pressurized piping advise sought
05/11/2007 1:05 AM
Does anybody know how to design a piping system for pressurized gases, especially one where the mass flow rate is not specified?
Thanks.
South Africa - Member - ShoSholoza Engineering Fields - Mechanical Engineering - New Member Popular Science - Weaponology - New Member
Re: Pressurized piping advise sought
05/11/2007 7:13 AM
The mass fow rate [when converted to volumetric flow rate] is required to determine the pipe diameter based on certain allowable pressure drops e.g. 0.5 kPa/100m. Without the flow rate, guess that you have to use engineering judgement the maximum that the upstream side can deliver or the downstream stream side can demand???
Else check other plants of simialr size or consult the vendors of equipment that this pipeline will service.
Failing that....limit the flow rate??? If there are no limits, you set the limits.
Can you imitate yourself?
05/12/2007 12:15 AM
What info do you have? Volumetric flow rate??? Anything???
05/12/2007 12:18 AM
you will of course need to be more specific,but one thing to consider is that once you move toward higher pressures, the standards are very different and meeting them is important. Especially if they are outside an experimental application.
Also, the standards relating to pressure piping are a good place to start as they tell you what you need to do to meet them......or at least you know what is required.
What specifically do you want to know about. You could fill a small library of books, standards and publications relating to pressure piping.
05/12/2007 4:59 AM
Design of a piping system include the followings:
1. Pipe sizing (pipe dia.), the gas flow rate (mass or volume) is necessary to determine the NPS, taking into consideration the total length of pipes, fittings, and valves to calculate how much the friction loss (drop of pressure) that affect the flow rate.
2. Pipe material is selected to withstand:
a. Gas corrosion/erosion. b. Stresses due to internal and/or external pressures.
3. Pipe wall thickness depends on : pipe size, pressure, temp., allowable tensile strength of material (SMYS) and procedures of manufacturing/construction and NDE.
According to ASME B31.8 (Gas Transmission & Distribution Piping Systems), the pipe wall thickness is :
t = P Do / (2S*F*E*T)
where, t = Nominal pipe wall thickness, in.
P = Design pressure, psi
S = Specified Min. Yield Strength (SMYS), psi
Do = Nominal outside dia. of pipe, in.
F = Construction type design factor (see ASME B31.8, Table 1-4)
E = Longitudinal joint factor (see ASME B31.8, Table 1-5)
T = Temperature derating factor (see ASME B31.8, Table 1-6)
Good Answers: 101
05/13/2007 10:07 PM
Okay, thanks for your advise guys. I wish I could be more specific, but the person who wanted my help didn't provide any specifics himself.
Abdel Halim Galala (1); Anonymous Poster (1); DVader1000 (1); Johnoz (1); The Hammer (1)
