Previous in Forum: Carbon Steel Flanges NDS 80"   Next in Forum: Boiler Question
Electric Motor Speed
05/20/2012 4:54 AM
hello guys i have electrict motor 1/2 hp 1500rpm and ill like this to reduce the rpm @ 200rpm!! that question?? what size or diameter of pulley that can be use from electric motor to a conveyor, the conveyor have 3inch dia pulley !
i want ot helf piple need assistance and to share my knowleged in technical
Re: electric motor speed
05/20/2012 5:48 AM
1500/200=7.5 3/7.5=0.4 You have to go to a larger pulley on the conveyor, or get a slower motor...or go to a multiple pulley system...or a gear reduction transmission...
http://www.jealco.com/Content/VendorMaterial/Mot_Red/Grove/Grove.asp
http://www.ebay.com/itm/Reliance-Dodge-Gear-Reduction-FC56WG12F8-7-5-1-New-z058-/220744796051#ht_500wt_976
05/20/2012 8:24 AM
Speed is directly proportional to diameter.
Sharing knowledge is one thing that defies basic arithmetic logic --- the more you share, the more you get!
05/20/2012 9:47 AM
Just use a .4 inch drive pulley.
Re: Electric Motor Speed
05/20/2012 2:23 PM
rpm1/rpm1 = d2/d1
assume d1 = 1
1500/1300 = d2/1
d2 = 1500/1300 = 1.15. You may have to use an adjustable pulley to get it just right.
Or you can go here and use the calculator
http://www.culvermotor.com/Engineering-Formulas/Pulley-and-RPM-Calculator.html
05/20/2012 11:28 PM
Misprint: It should be rpm1/rpm2 = d2/d1.
The OP can clarify whether "@" = "by" or "to", which would be 1300 or 200 output rpm, respectively.
05/21/2012 11:18 PM
A minimun motor pulley , for a "A" v belt profile , could be about 2 inch , so your conveyor pulley shall be 2 x 7.5 , or 15 inch diameter
devitg
Register to Reply 6 comments
bravo88 (1); devitg (1); lyn (1); SolarEagle (1); Tornado (1); wareagle (1)
