Previous in Forum: Flip Flop and ROM   Next in Forum: LT SWGR Erection & Testing
Insulation Film
05/21/2012 7:41 AM
Hello,
We have 400KVA alternator that need to be rewind, but we cannot find in the market the insulation material it is a 3 ply paper/something like mylar(milky white)/paper the overall thickness is around 0.80mm I measure the middle film looks like mylar the size is around 0.30mm. the winding insulation class is H. There are two kinds of insulation used, one is 0.60mm 3 ply also.
Anybody know the exact name of the insulator? I found one called Nomex/Mylar/Nomex but the max thickness they have is 0.50mm.
We have expierence in rewinding motor from 100hp down to 0.37kw. But Generator not yet.
Darial
India - Member - Proud to be INDIAN Engineering Fields - Power Engineering - New Member
Re: Insulation Film
05/24/2012 3:14 AM
"NOMEX TYPE 410" is available in 12 thicknesses (0.05 to 0.76mm). It can withstand temperatures from 200 to 250 degrees without breakdown. All characteristics are available (Electrical, mechanical, thermal & chemical).
Just google NOMEX TYPE 410.
I used it and its good.
sharath
you need to go, to get something
