Previous in Forum: Computer Wire   Next in Forum: Power Co. Capacitors Cause VFD's to Kick Out
Current Transformer Question
05/27/2012 12:56 AM
My system defines 500/1A CT. Actual requirment is 400/1A. Can I use 500/1A in place of 400/1A CT. Please Help.
India - Member - New Member
Good Answers: 164
Re: Current transformer
05/27/2012 6:28 AM
It is not clear what you mean by 'actual requirement' and 'system definition'. Well, assuming that you mean that the actual current is 400A, (so that you want to use a 400/1 CT), are you sure that the meters, relays or whatever that draw current from the secondary are not designed for 0.8A rather than 1A? If you are sure, then you should ask the person who specified 500/1A as to why he/she did so. i don't think it is ok to take a decision on your own.
05/27/2012 10:52 AM
Make sure the CT ratio matches the meter's scale ratio.
Good Answers: 181
Re: Current Transformer Question
05/27/2012 2:40 PM
Just put a piece of tape on the meter and write "X .8"
Should do the trick.
05/27/2012 2:50 PM
05/27/2012 3:03 PM
Probably, if you can electronically scale the 1A signal for a 0-400A range and keep the required CT resolution and accuracy.
jack of all trades (1); kvsridhar (1); TonyS (1); Tornado (2)
