Previous in Forum: Transmission Capacity Of An Optical Fiber   Next in Forum: Battery
220V Synchronous Motor With PWM Inverter?
05/30/2012 8:16 AM
Can we run (220VAC, 4rpm, 4W) Synchronous Motor with 100W 12VDC to 220VAC PWM Inverter? Will there any effect on motor operation by using PWM Inverter?
Re: 220V Synchronous Motor With PWM Inverter?
05/30/2012 10:48 AM
The two are compatible, although the inverter might be a little over-sized for the job. However, given the low retail value of such a device, it isn't worth re-sizing it.
Go for it. Do report back on how well the combination works.
