Previous in Forum: What Statistical Approach for Maximizing Output?   Next in Forum: Pigging System Issue
Quality: Fillet Leg Length Size for Tree Joint
06/01/2012 1:10 AM
what should be the fillet leg length size for 10mm thick to 10mm thick Tee joint and
36mm thick to 12mm thick Tee joint?
Re: Quality: Fillet Leg Length Size for Tree Joint
06/01/2012 8:00 PM
The rule of thumb, on a T joint with fillet welds on both sides, is 3/4 of the thinnest material thickness equals a full strength weld. When welding 2 different sizes, the throat depth should be calculated using the thinnest one's thickness...but it's all here...
http://www.wtia.com.au/pdf/TGN-RT-05%20-%20Guide%20to%20Fillet%20Welding.pdf
Good Answers: 29
06/14/2012 10:29 AM
Additionally; fillet weld size is the effective throat not the leg length.
Si vis pacem, para bellum
Register to Reply 2 comments
