Previous in Forum: SUBSEA - Oil & Gas   Next in Forum: Scheduling of Steam Turbine Inspection Intervals
A53 Grade B
06/02/2012 11:30 PM
sir,
how i know the diffrance between A53 garde A and B pipe
pradeep
Pathfinder Tags: A53
Re: A53 Grade B
06/02/2012 11:53 PM
"A53 pipe comes in three types and two grades, A53 Type F, which is longitudinally furnace butt welded or continuous welded (Grade A only), A53 Type E, which is longitudinally electric resistance welded (Grades A and B), and A53 Type S, which is seamless pipe, produced by hot working, and possibly cold finishing, the steel (Grades A and B). ASTM A53, Type S is now currently an outdated specification and has been replaced by ASTM A106 specification for seamless carbon steel pipe."
There is very little difference other than the weld seam on the grade B pipe is heat treated and has a higher tensile and yield strength....The pipe must be labeled one of the following; Continuous Welded, Electric-Resistance-Welded A, Electric-Resistance-Welded B, Seamless A, Seamless B, XS for extra strong, XXS for double extra strong.
http://www.amerpipe.com/products/carbon-pipe/a53/specifications
http://en.wikipedia.org/wiki/ASTM_A53
Re: A53 Grade B
06/03/2012 12:33 AM
Grade A also passes a flattening test for close-radius bends, as in forming serpentine pipe coils for refrigeration. It isn't a high-pressure pipe.
Register to Reply 2 comments
