Previous in Forum: One Hundred Years From Now   Next in Forum: Difference Between 16 inch 45cal and 16 inch 50cal Guns
Life Span of a Sea Water Cooling Line in MODU
06/03/2012 1:34 PM
Hi All,
What will be the life span of a Sea water cooling line made of Schedule 40 A 53 GrB without coating ?. Subject line is in a Rig for D Gen Fuel oil cooling purpose.
Appreciate all valuable comments, even though it' s an assumption..
Many thanks.
Re: Life span of a sea water cooling line in MODU.
06/03/2012 3:23 PM
You will probably lose 5-20mil pipe surface due to corrosion per year...Depending on depth, galvanic forces, temp etc....Just guessing...
Good Answers: 114
Re: Life Span of a Sea Water Cooling Line in MODU
06/03/2012 9:02 PM
You cannot say what the lifespan of the pipe is without knowing the corrosion allowance in the design, that is an thickness over and above that needed for strength as a structural element and as a pipe.
A web search finds several sources of info on corrosion rates.
06/11/2012 4:24 AM
It will be much shorter than one made from plastics or glass-reinforced polyester.
Register to Reply 3 comments
passingtongreen (1); PWSlack (1); SolarEagle (1)
