Previous in Forum: Instrumentation Grounding   Next in Forum: Changes to Save Energy
Neutral from Y Transformer
06/04/2012 6:08 AM
I'm installing Sinamics MV Drive that is fed from 3 winding transformer Ddyn.
The drive only provides 6 connection point, 3 on each transformer as shown in the drawing below. What should I do with the neutral from the Y transformer?
Re: Neutral from Y Transformer
06/04/2012 8:00 AM
The neutral on the secondary side of the medium voltage transformer is there to stop the secondary from floating. If you only need a 3 phase (3 wire) feed then only use those. You don't have to use the neutral. I can't ever remember using the neutral on a MV system. I do use it frequently on 208/120, 480/277 and 600/347 circuits (277 and 347 lighting).
It is likely that the input transformers in your drive are floating on the secondary side which helps the gates generate a relatively smooth DC bus charge.
I am a little concerned given this question that you may be a little out of your comfort zone. Make sure you study the drawings that came with the drive and most importantly get a licensed electrical engineer that is familiar with this type of installation review and stamp the installation drawings. This is MV! A mistake can have serious consequences.
What does 'Ddyn' stand for?
Good Answers: 170
06/04/2012 11:44 AM
The neutral may be left floating as the load is a three phase three wire load. The Ddyn is only to neutralise the 5th & 7th Harmonics at the input side of this trafo.
06/04/2012 9:53 PM
I'm still wondering what is a Ddyn? Is it a filter of some kind? What does Ddyn stand for?
Regards,
Frank
06/04/2012 9:59 PM
It's a three winding transformer, with D on the primary winding, and D + Y on the secondary winding
06/06/2012 4:04 AM
The correct meaning of Ddyn has been correctly pointed out by others in this discussion. The reason for -dyn is to give different phase vectors to the two windings of the secondary and hence a smoother combination to DC after rectification.
I attend work so my dogs can have the good life.
Doggoneit (1); electricalexpert65 (1); frankdolan (2); Local_Eng (1)
