Previous in Forum: Wave Propagation and Surprising Tsunami   Next in Forum: CAD Users
14 comments
Whitworth Thread Gauge 12G
06/09/2012 9:17 AM
Hi All
I have a prop shaft that requires a nut, my Whitworth 55 deg Thread gauge idents it as 12G? the shaft is 3/4" across the threads and 12TPI.
I've been told that a 3/4 BSW should be 10TPI so perhaps my shaft is BSF? and my Whitworth gauge has BSF leafs incorporated.
I've taken this info to a couple of suppliers in my local area but none of them are up to speed with Whitworth and unwilling to commit to manufacturing a nut without a positive identification of my requirements. i.e. "I want a 3/4 BSW Nut", "I want a 3/4 BSF nut"
Can anyone throw any light on this situation? it's been 27 years since I did my apprenticeship and my memory isn't what it was so I've tried the internet but all I've found is contradictory advice.
Regards
Pathfinder Tags: Whitworth
Re: Whitworth Thread Gauge 12G
06/09/2012 10:10 AM
06/09/2012 5:02 PM
3/4" BSF is 12 TPI and 55 degree thread form.
http://www.vdwalle.com/knowledgebase/draad/bsf1.htm
Good Answers: 266
06/09/2012 10:34 AM
3/4-12 could be Unified Thread Standard. Make and model of the device the shafts on?
06/09/2012 11:42 AM
Cheers for the replies.
Shaft is fitted to an old (1960-70's) Petter AC2W deisel engine and gearbox fitted to a small boat, I have no idea of original manufacturer of the shaft and coupler.
I think UTS is 60deg, if the thread gauge is to be believed mines definately 55Deg,but thinking about it, it must less than 55 deg to accomodate the 12TPI, threads are also rounded at peaks and troughs as whitworth but i suppose this could be down to its age?
I've got a memory of a thread that had a pitch of 47deg? i suppose it could be this. back to the internet i think.
razor
Good Answers: 58
06/09/2012 12:27 PM
Have you tried a 3/4" nut on it? It should not be hard to find one. Coat the threads in hard grease or wax to see how the fit went. If it doesn't rattle or bind, it may be ok.
mike k
06/09/2012 2:14 PM
http://www.timebus.co.uk/rlh/whitworth.htm
Yes should be 55º...You might try measuring the width of the shaft, they vary between the BSF and BSW....BSW being 1/8" wider than the BSF, according to this chart....at least that's my take...7/8" for BSF and 3/4" for BSW...
Good Answers: 97
06/09/2012 3:20 PM
you'll find this invaluable the three wire method
the three wire method plus
plus charts
Location: "Springwood", North Tamborine Mountain. Qld. OZ.
06/10/2012 3:04 AM
Hi Razor,
3/4 BSF has all the specs you've encountered, including the relatively big tip and root radii.
Basic effective diameter will be approx 0.6966", with the minor dia. being 0.6432".
Is it a bronze nut on a 304SS shaft?
Stu.
"Nothing, is as it seems." Dr Wally.
06/10/2012 7:49 AM
Hi "I've been told that a 3/4 BSW should be 10TPI so perhaps my shaft is BSF"
If you give these details to a good machinist he or she should be able to make you a nut without any problem. If the machinist can not do it with this information then find someone else who has a brain.
06/10/2012 5:48 PM
Remember that manufacturers sometimes made a proprietary thread to force you to purchase replacements from them. So, if this doesn't match Whitworth standards, it may be a special. Of course this presents a problem to we folks who deal with old stuff.
Lehman57
06/10/2012 5:53 PM
You could make a wax mold of the threads...This with a micrometer reading of the dia should be enough for the machinist....
05/18/2023 1:26 PM
05/18/2023 2:36 PM
05/18/2023 11:35 AM
If a 3/4"BSF bolt were to hand one could try offering and meshing thread-to-thread to see if there is a fit, perhaps.
Register to Reply 14 comments
bwire (1); garth (1); Lehman57 (1); lyn (1); mike k (1); ozzb (1); PWSlack (1); razorrae (1); SolarEagle (4); Stueywright (1); woodygb (1)
