Previous in Forum: Siemens Steam Turbine   Next in Forum: Hydraulic Spool Valve ID
India - Member - Mechanical Engineer Engineering Fields - Petroleum Engineering - Mechanical Engineer
Crane Bridge Service Factor
06/14/2012 7:22 AM
hi there,
i cam across this term Plugging while sizing the motor for trolley as per IS 3177 in Table 21B Values for service factor. can some one enlighten me on this as to what is plugging in cranes??? thanks in advance.
Varun Passi
Pathfinder Tags: Eot crane Plugging
Good Answers: 29
Re: Crane Bridge Service Factor
06/14/2012 7:31 AM
According to Engineered Material Handling's Glossary of Terms:
Plugging: A control function which accomplishes braking by reversing the motor line voltage polarity or phase sequence.
Si vis pacem, para bellum
06/15/2012 2:31 AM
thank u very much.
Varun Passi
Good Answers: 266
06/14/2012 7:51 AM
Like most motors they don't like it when going full speed in one direction someone switches to the other with out coming to a stop. So they have circuitry that does it. Pulses to the motor braking the direction of travel until it stops. This is plugging.
Usually found of equipment where an operator has control of directional motion and speed. Fork lifts and cranes are a few.
06/15/2012 2:31 AM
thank u very much.
Varun Passi
Good Answers: 102
06/16/2012 4:52 AM
So, "plugging" is another word for dynamic braking/holding.....
Why is it called "plugging" I wonder?
ozzb (1); PMoon (1); varunpassi (2); Wal (1)
